Question about AT&T Blackberry Curve 8300 Smartphone
Why cant may phone accept or recieve calls? I get a failed call
Signal.
    Brigadier General:
  • 7,752 Answers
You will need to take the phone to a mobile repair shop and haev the techs look at the problem for you, maybe the antenna is faulty.
Posted on Feb 04, 2010
I need register my sim card
Depends on the network.
sims have to be registered to work.
All others usually work straight away but smetimes with you have to top up before it will accept incoming calls.
If you have a signal but cannot recieve calls try topping up
Nov 09, 2014 | Cell Phones
Network error
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jul 28, 2012 | HTC Wildfire Cell Phone
I cant send or recieve faxes
Unplug the HP from the phone line. Connect any regular phone, do you have a calling signal? Can you outdial and receive calls? If so... Check if you're plugging the phone cable to the "LINE" not "EXT".
Mar 05, 2011 | HEWLETT-PACKARD HP 2140 Fax
G1 screen doesnt work, stays black, but still works.
Did this happen all of a sudden? Was the phone dropped? Chances are the backlight in the screen went out or the ribbon cable inside the phone that connects the screen some how came loose.
Aug 25, 2009 | HTC G1
Cant answer phones as it gets froze and cant recieve calls
U may need to reformat it ie. Jailbreak and unlock. But thats if its out of warrantee,
Aug 20, 2009 | Apple iPhone 3G
How come my Nokia 7610 cant send anymore txts and cant recieve any either?? it also cant accept any calls.. and also my phone battery gets drained so easily
Hi!... If the phone has signal an then you can't send and recieve text try to goto> Message> Message settings> Message Center Number or Center number , then compare it with another user with the same network if its the same or else copy his/her Msg Center Number if he' she is able text... And for your battery problem, how long are you using the battery?... If you always leave it overnight charging so it might be damaged or leak,... Try to buy a new battery...
Jun 19, 2009 | Nokia 7610
Cant make or recieve calls
Take the SIM card out and re-install it. You may need to call your phone provider and have them unlock the phone.
Good luck.
Mar 19, 2009 | Motorola Mobility RAZR V3
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
AT&T Blackberry Curve 8300 Smartphone Logo
53 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
