Question about VeriFone Omni 3700
Verifone 3750 getting a blank screen
Several times within the last couple of days the screen on the machine goes blank. We have to unplug and replug the power cord. I've ck'd all connections for power & data. What is wrong?
Beni S-P
  • 1006 Answers
SOURCE: barcode scanner for Verifone Omni 3750
http://www.allthingspos.com/assistance/drivers.htm
Here u have if u need manuals or driver
SLOVED???
Posted on Oct 18, 2007
SOURCE: verifone omni 3750
To do those kinds of tasks on the Omni 3750, you need to put the terminal into "system mode". Since once in "system mode", you can not only erase the previous applications, but you can also erase the operating system, I do not want to post that information on the web for everyone to see. I would recommend that you contact a terminal repair shop and ask them to walk you through that process.
Do you have the capability to reload the operating system?
Posted on Jul 01, 2008
  • 6 Answers
SOURCE: Verifone Omni 3750, set up problem
Your processor should be able to essentially blow out the memory on the terminal. From their a dummy program can be loaded to finish wiping out any residual memory. Lastly, you will need to do a completely new core load with your actual file build. The process takes much longer than normal due to the multiple core loads but it is effective. If your processor is not familiar with this or is unable, I would be more than happy to take over your services but am unable to solicit on this site. So, feel free to email me with any questions you may have at CJepson@federal-financial.com. Hope this helps.
Posted on Aug 28, 2008
Use this Master Password from the manufacture #23378463
Posted on Mar 22, 2009
  • 14 Answers
SOURCE: how do i change the
It does not use ink, it used a thermo printer, need th thermo paper.
Posted on Sep 09, 2010
Mac tools et80
Water is not spraying out
Feb 22, 2014 | E-Machines Computers & Internet
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
I have a verifone 3750 terminal when stated message on thescreen is " download needed no *go variable" 1alpha alpha 66831 do not work
Press the F2 and F4 keys at the same time and it will then prompt you for a password. Enter 1alpha alpha 66831.
This takes you to the programming screens where your processor enters in their platform settings to perform the software download for your account. Without a valid download from your processor, the terminal will remain a blank slate.
Hope that helps
Aug 19, 2009 | VeriFone Omni 3700
I need to change the gateway in my verifone omni 3750. How to put the period after the number? rathin
Hit the * make sure it says CREDIT/DEBIT and Commserver choose commserver. Hit the last purple key (reports) key. Then choose IP change it to static and fill in the blanks and when each field is done hit next.
To get the periods or dots. Hit 1 then the alpha key above number 2 to get the dot.
Call me if you still need help.
www.greenlightpayments.com ext 105
Jul 01, 2009 | VeriFone (M19755014US1) Magnetic Card...
Add Credit to Gift cards with Verifone Omni 3750?
Get in touch with a gift card company or you processor (as many have programs) they will set you up with a program and cards and put the program in the machine.
Mar 10, 2009 | VeriFone Omni 3700
3750 fails to complete transaction
it needs to reprogram the machine
erase all of Memory and cache
ask your processing company, build NEW terminal file
and install fresh one.
Sep 25, 2008 | VeriFone Omni 3700
Samsung 40 inch LCD
Are you still having problems?
Jun 28, 2008 | Televison & Video
May 27, 2008 | VeriFone Omni 3700
Retail Supplies Logo
344 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
