Question about KitchenAid 24 in. KUDP02FR Built-in Dishwasher
Sounds like garbage disposal running not
Sounds like garbage disposal running not dishwasher
We shall not be so irrisponsible to our own dirty because it can affect to our own family.
Posted on Aug 01, 2010
How do we remove the horrible smell in our Bosch dishwasher?
First check out your model to see if it has a built in garbage disposal, if so, make sure it is not mucked up.
Run hot water down your sink drain while running the sinks garbage disposal. Pour baking soda down your sink garbage disposal followed by white vinegar. Let it sit and foam. Run hot water down sink disposer while running. When finished:
Run empty dishwasher with no soap, let dishwasher fill with hot water to wash and then pour 1 cup of white vinegar into the bottom and resume wash. Make sure you take it through the dry cycle. When finished, open dishwasher and let it air for a couple of hours, longer if you live in humid area. Hope these steps do the trick.
Aug 03, 2014 | Bosch Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Feb 10, 2012 | Asko 1385 Dishwasher
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool motor does not sound like it kicks on when started. The dishes are not getting cleaned...and water remains in the bottom. When I hit drain, it will drain. I also recently noticed that I am...
Yes it's most likely related. Your dishwasher dumps all the debris it washes off the dishes into the garbage disposal. I'm not a dishwasher distributor so I can't tell by the model number just what dishwasher you have.
Most people dump little thing in the disposal through out the day with out thinking about it or running the disposal, try running the disposal while your running the water to warm it up.
If your dishwasher has a built in garbage disposal, then from what you've described I would say something either a small metal utensil or a piece of glass has gotten down into the dishwasher's disposal and damaged the blade.
If your dishwasher doesn't have a disposal then it's most likely gotten into the pump impellor and broken off some off the teeth.
Another thing I've run into is that the lines inside the dishwasher get holes worn into them, either from the hot water going through them or the spray, I don't know which is the cause. Pull the trays out turn the top one over and check the line for damage. While the trays are out check the other lines and the pump for visible signs of damage.
Jun 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Replaced disposal and now dishwasher isnt draining
It sounds like you've done everything fine. I would disconnect the dishwasher drain line from the disposal, have a bucket ready and see if it will drain. It's possible that there is a plug or something else left in the disposal opening that is blocking the water. If the dishwasher won't drain with the hose off of the disposal, there is a problem with the dishwasher that has nothing to do with your disposal installation. Hope this helps and good luck!
Mar 12, 2010 | Dishwashers
my dishwasher did the same thing last week and it was the garbage disposal. I had to run the garbage disposal and clear it out and then reach my hand in the dishwasher to check for any items blocking the drain. I had nothing and clearing out the garbage disposal did the trick.
Oct 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Once my dishwasher completed the cycle there is no water but after two or three days the bottom of the dishwasher fills with the dirty water. what could be the reason? I have garbage disposal and one pipe...
You must have your dishwasher connected directly to the garbage disposal and not through an air gap. What is happening is when you disposal fills with water it is siphoning through the drain hose back to the dishwasher. If you sink has a spare hole on the deck install air gap and run dishwasher drain through air gap first. Otherwise make sure you run Garbage disposal often so that water does not get slowed and build up inside.
May 11, 2009 | Frigidaire 24 in. FDBB944C Built-in...
How do you clean out a clogged drain hose from the garbage disposal to the dishwasher?
You may have to pull the dishwasher out and remove the clamp on the hose from the pump. run a snake or a coat hanger or anything else that you be long, flexible but stiff enough to move through the drain. You might be able to go from the disposal side back to the drain. This would be easier if you can. If you run water down the disposal side does it back up into the sink? If it does, then the clog is down below the disposal and not the dishwasher side.
Apr 08, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Oe code on LG dishwasher following garbage disposal replacement
Hi. I just had the same trouble. Your garbage disposal comment there gave me an idea. The drain hose from your dishwasher likely goes to the garbage disposal and then out the drain. My hose had a little blockage at the joint where the hose goes into the disposal. I was able to clear it just by giving it a wiggle....all is well now.
Good luck.
Sep 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
KitchenAid 24 in. KUDP02FR Built-in Dishwasher Logo
95 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
