Would like to know what all the buttons on front of chasis but below screen are for AND how to use them.
    President:
  • 1,179 Answers
Depending on your monitor those are the volume, menu, & different function buttons such as brightness, contrast, sharpness. You'll have to look in your monitor's owner manual to see what each specific button if for but what I mentioned are the most common. Hope this helps.
Posted on Mar 06, 2009
CHASIS NUMBER JMFMNCJ2AKJ
Chasis ???dont you mean chassis number --- well forget the one in the windscreen thats not acceptable for the annual inspection ...top of bulkhead/sorry firewall ,rear chassis frame behind the wheel ,front chassis behind the wheel ,in the boot /trunk ,but some american cars actually put them under the carpet behind the brake pedal.sorry i dont know where exactly we dont have these cars in spain
Sep 11, 2012 | Mitsubishi Mirage Cars & Trucks
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
How to open the Acer mini-tower Desktop?
Acer Chasis has two screws at the back, which you should open. After removing the screws press the Black T-Shaped button down and pull the side lid backwards to open the chasis as marked/ shown below: -
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 27, 2011 | Acer Aspire™ T180 PC Desktop
Veriton M460 How can I open the chassis
Veriton M460 Chasis has two screws at the back, which you should open. After removing the screws press the Black T-Shaped button down and pull the side lid backwards to open the chasis as marked/ shown below: -
CreativeTECH
Jun 29, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
We washed a small rug and we got an E-20 code. what should we do, its having problems draining!
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Jul 12, 2009 | Frigidaire GLTF2940ES Front Load Washer
Hitachi 53UWX10BA HDTV adjusting color
Hi, Your tv model has a small light blue color button inside for manual adjustmnet mode. You will have to remove the front covering below the screen. its just attached with velcrow. Then there will be a centre wooden pannel with the the switching box screwed to tv front with around six screws.Open this panel and look to the left corner of the chasis boards in front of a small metallic box. Thats the switch you have to press to get into manual adjustment mode. use remote to adjust the colors. once done press it again to exist. Visit www.fixurtvs.com to find out more about tv FAQs. Thanks if you found it helpful.
Apr 29, 2009 | Televison & Video
Fuel filter replacement 1999 4runner
Under vehicle, passenger side, below seating area, front of fuel tank, mounted on chassis
Dec 15, 2008 | 1991 Toyota 4Runner
Chasis #
chasis ???dont you mean chassis number --- well forget the one in the windscreen thats not acceptable for the annual inspection ...top of bulkhead/sorry firewall ,rear chassis frame behind the wheel ,front chassis behind the wheel ,in the boot /trunk ,but some american cars actually put them under the carpet behind the brake pedal.sorry i dont know where exactly we dont have these cars in spain
Nov 22, 2008 | 2005 Chevrolet Silverado
High voltage splitter
I have read on this forum that for the Proscan 60690 Chasis # PTK 188AC, the HV Splitter part # is 205064 and can be easily purchased on eBay for around $20.- $25.
Sep 28, 2007 | Proscan PS60690 60" Rear Projection...
Computers & Internet Logo
122 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
