Question about Dell OptiPlex GX520 PC Desktop
After inactivity for few minutes the screen goes blank
I did a clean install of all programs after wiping the drive clean and creating a new partition on the drive. After the machine is idle for a few minutes the screen goes blank (blue color). user hits space bar or moves mouse the screen comes to log in. user logs in and the screen goes back to blue. no other activity. if you touch the power button the computer restarts immediately. The power options are set for 'never' on everything and hibernation is off. I did get the system battery is low prompt at one time but have not seen it in a while.
  • 1 more comment
  • steve851 Mar 06, 2009
    On resume, password protect is unchecked.
    OS is windows XP pro I used the disc that comes with a Dell direct purchase. SP2
  • Matt H
    Matt H May 11, 2010
    If this is a desktop, you should not be seeing anything related to a laptop's battery and power. Can you provide information about the disc you used to install your OS?
    Sergeant:
    Champion:
  • 224 Answers
What about the screen saver
Posted on Mar 06, 2009
  • Shakeel Muradali
    Shakeel Muradali Mar 06, 2009
    You might have installed Tweak that you can access in the control panel. Check that for Automatic login. That might be the issue
I have formatted the boot partition (winXP Prof pre -installed) and installed Windows 7 and after BIOs the screen goes blank
Hi pratimpal
You should have directly upgraded to W7 instead of formatting . Try reinstalling Windows 7 on the same partition , it should work . Otherwise , back up all data on an external device , format entire drive while installing W7 and create new partitions afterwards with http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html
Best regards ,
fanaudi .
May 03, 2011 | Computers & Internet
I have a diamondmax plus 8 40 gb HDD that I am trying to install in a Dell computer. The drive that came with the machine is a diamondmax plus 8 30 GB HDD. I have tried two different XP install disks and I...
If you get that error when you are at the screen for selecting a partition in windows XP, then if you have the hard-drive as master, the cable is correctly hooked up, your drive needs to be erased, reformatted.
There is a few ways of doing this, first way is to wipe the disk clean, I use a program called disk wipe you can get it here:http://www.diskwipe.org/download/DiskWipe.exe, use this to wipe the disk clean, usually the boot information would be on the first part of the drive, so you can run a quick wipe, i usually just wipe the first 3 or 4 gigs. After that you can use windows XP again, you shouldn't need a driver for the hard-drive, but if you do, windows will give you that option, then proceed to new install, and to the partition area, the drive should show up, if it does, then you need to delete that partition, create a new partition, and reformat that partition, then click next to continue the install or follow instructions to install that os.
The other way is to hook the drive up to the same computer or another computer as a second drive, where you have windows installed on the first. Then in windows go to computer select that drive right click on it and it will say format, click format, and select quick format, then ok to format the drive, if at this stage you still don't see the drive, then you have to go to control panel, administrative tools, disk management and the drive should be visible, you should then be able to right click where it says disk o or disk 1 which ever disk, if you only have one disk hooked up then you'll see it, it is probably offline so you need to click on line, or make active, once you do that, you can right click on the hard-drive next to where it says disk, and select format which should now be allowed, format it, and then it will show up as a drive under my computer, once it does, you can then install windows on it without any problems.knoppteria4.jpg Once it is formatted it will say healthy system. The reason hard-drive is not being recognized is because it isn't formatted correctly, the above always fixed this issue, unless the hard-drive is defective, which is the other reason, and one other reason is that when windows ask for 3rd party drivers you might need the driver for that disk which when it ask for 3rd party drivers, you would put the driver in, from a disk or another drive. Hope this help's, i have ran into this issue hundreds of times, some on my own disk, it happens, but is most of the time easy correct. Also as a tip make sure your bios is set properly for that drive, and that in your bios you can see the drive before you install windows.
Nov 30, 2010 | Maxtor Hard Drive
Step of installing windows xp professional
Step 1. Basic Installation Start the computer and insert your windows xp cd. After a few seconds, the screen will clear and you will see a 'press any key to boot from CD' prompt. Press the any key..... he he, there is no 'any' key, this is just a test ;)
Press any key to start the install. The prompt allowing you to install will time out after about 4 seconds, so if you don't hit any of the keyboard keys you will have to reboot to install.
The installer program will begin copying files from the CD.
The 'welcome to setup' screen appears. Press enter to continue. View the licensing agreement and hit F8 to continue.
The installation program will then search your drives for any prior installation of XP. If it finds one, you will be given the option to repair it, which essentially reinstalls most system files while leaving the registry and installed programs intact. Otherwise, move forward to the partitioning and formatting section of the install.
The initial screen shows the hard disks connected to your system, and any partitions that may already be created.
A partition is simply a section of the free space on your hard-drive. Operating systems use partitions to logically assign drive letters. For example, if you have a single 40GB drive, you can allocate all the space to a single partition, but then you could only have a single drive (C:) visible in Windows.
If you chose to divide that 40GB into 4 different 10GB partitions, you could have 4 individual drives (say C:, D:, E:, and F:) within your Windows environment. Essentially, Multiple partitions allow multiple logical drives within a single physical drive, and can even allow different operating systems to co-exist on one drive if desired. Once a partition has been created, it must be formatted to be useful.
Aug 04, 2010 | Microsoft Windows XP Professional
How can i format my pc& how change my os from ubuntu to windows xp
The following tutorial will help you reformat your hard drive and reinstall windows. I personally reformat my HDD and reinstall windows at least once every 3 to 5 months. After your first successful reformatting, you'll wonder why you didn't try this earlier. This is one of the first things I taught myself because I knew I was going to make a mess of my system...alot. Anyway, Please note, I am not responsible for any damage although I don't see how you can possibly damage anything whilst reformatting. Follow these steps exactly and you should be fine.
Step 1: Make sure you have your Windows XP disk. I personally delete everything I don’t need, and uninstall all programs that I don’t use. I then make a list of all the programs I still have installed and download all the installers I will need. Also download Spybot Search and Destroy and Ad-Aware but do not install them. I then backup all my important data and all the installers onto a portable hard drive – if you don’t have one you can build one (see HERE how to build your own external hard drive cheaply) or you can use DVD’s or CD’s. Make sure you have everything backed up and then disconnect the portable hard drive.
Step 2: Insert your windows disk into the Master CD drive (if you have more than one) and turn the computer off. Make sure you are disconnected from any networks. You will need to have your cd drive selected as your first boot device. If it not already selected, you will need to go into your bios and set the boot priority to cd/hdd, then with your Windows cd in your cd drive, save and exit bios.
Step 3:
Turn on your computer. A screen will come up saying “Press any key to boot from disk”. Press any key (where’s the “Any” key gone?!). Now wait about 10seconds for the setup utility to be loaded. When asked if you want to set up or repair, hit Enter to set up Windows. Read the license agreement and hit F8 if you agree. If the setup program detects an existing installation of Windows and asks if you want to repair it, hit Esc to skip the repair. The setup program will ask you where to install Windows. Highlight the existing "C: Partition1" partition and hit D to delete it. Hit L to confirm. Next, hit Enter to install Windows on the "Unpartitioned Space". Format the space as NTFS - You will get an option to choose full or quik format. My experience is that quick format is for disk that have previously formatted. If the disk has not been formatted, then you will have to use the standard format option. Usually you will get a popup message "This disk can not be quick formatted" or something along that line. Then continue the installation. Please note: During the installation process, your computer will reboot. You will then see a message to press any key to boot from cd. Do not press any key a second time, otherwise the installation will start from scatch again. Complete the next several screens on the setup process and make sure you do not leave the administrator password blank. After following these steps, setup should be complete.
Step 4:
Firstly you should install your antivirus software, Spybot S&D and Ad-Aware. Also enable the windows firewall by going to Start>Control Panel>Network and Internet Connections>Network Connections (icon on the bottom-right)>Right-click the Local Area Connection>Properties>Advanced tab>Check the box next to "Protect my computer and network...">OK. After this has been done, install all updates from the Microsoft website (including windows XP service Pack 2). Then install all drivers from your motherboard utilities CD. Now it is time to install your programs.
Step 5:
Enjoy the brand new feeling of your Reformatted PC
Hope this tutorial will help some people.
Watch this 5 minute video tutorial before you start...
Jun 24, 2010 | Computers & Internet
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
Mar 04, 2010 | Computers & Internet
Hardisk cleaned why?
this may be a hdd physical failure, best to check this would be to connect disk to another computer for a minute and run full HDTACH tests, if it's not damaged, then boot record is damaged, and Partition magic or similar program is needed to delete partition and re-create it
Sep 19, 2009 | Western Digital 250GB MyBook External USB...
How do you wipe the compaq presario m2000
I'm not sure if you are wiping it to start over or to sell/give away.
Many newer machines have a Recovery Partition, usually your "D:" drive.
Access the System Recovery partition from the Start-All Programs-System Recovery-System Recovery Menu. Following the prompts will allow you to reformat the computer and reinstall the operating system and all software as it came from the factory. From that point, if you don't want any of the factory junk, you'll need to uninstall it yourself.
If the Recovery partition is missing, (usually a D: drive) , then you'll need to have the original Recovery discs which were created when the computer was new.
If you simply want to wipe it, use a disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads.com to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
Read more: http://pcs.suite101.com/article.cfm/wiping_your_computer_hard_drvie#ixzz0RZDlV3Qr
Sep 19, 2009 | Compaq Presario M2000 Notebook
Operating system not found
You can't insert a Hard drive from another PC because when it was installed on the old PC it was setup to work with the hardware for that particular computer.
You will need to reinstall a fresh copy of windows on it to make it work with the new PC it's in.Boot from CD run windows setup, format the drive then do a fresh install.
This should fix the problem, if you have any new info or need further help with any of that post back. Thank you for choosing Fixya!
May 27, 2009 | Microsoft Windows XP Professional
Tried to reboot to factory settings
You have to make sure when going through the setup (if given the option) to install a clean copy and not install windows to another directory. If you have access to a floppy disk drive an easier way would to be to create a dos boot disk and reformat your c:drive. Make sure you do not have any data on this laptop you want to save. If that does not work you can try to get a DOS program called FDISK. It will wipe out the hard drive partitions so that you can reload your laptop from scratch. Let us know how it goes.
Apr 27, 2009 | IBM ThinkPad T23 2647 Notebook
Could you help me with partitioning my hard drive please?
OK, this should be very simple.
First: Put in the recovery disk with XP, when it boots up to its main screen you should be given different option (eg, Repair, Format, Install new, etc...) It is different with every computer but if you read the options they are usually self explanatory.
I suggest you try the option that formats the Hard Drive and Installs a new copy first, as sometimes this works and could save you some time and effort.
If that doesn't work and you get the file system error you are going to have to do the partition thing to completley wipe the file system from the hard drive.
To do this: Reboot the computer untill you get back to that main screen and in there you should see an option to partiton the hard drive. Once in the partition software you will be given a few options like 1. create a new partition 2. create a logical drive 3. delete a partition.
First delete all active partitions, second create a new partition (here you can select if you want to use your full drive so you only have a C drive or you can split it to multiple drives, eg C,D etc.)
If you chose multiple (which i recomend, so you can save all important files to D so if you ever have to re-run your system you won't lose those files) Create your C drive by selecting how much space you want (usually 1/2 to 3/4 of the drive) then select create a new partition again and create your D drive with the space that is left (it will give you instructions as you go, just stick with the defaults) when you are finished select the second option to create a logical drive (again just let it do its thing and stick with the defaults) when you are done reboot and from that main page you will have to format both drives (or just the one if you chose that option) and Install windows again with a new install (not a repair or recover as it might try to do this from your previous attempt at installing.) thats it, if you have any questions don't hesitate to ask.
Also Vista does have the option of using either FAT32 or NTFS so really it depends on which way it was installed, if it was installed with a FAT32 then you will have no problem just intalling XP from the start. You will only have to do the partition thing if it was installed with the NTFS file system.
Hope this helped you!
Let me know either way!
Mar 27, 2008 | Sony VAIO VGN-FJ270/B Notebook
Dell OptiPlex GX520 PC Desktop Logo
482 people viewed this question
Alun Cox
