Question about Toshiba DKT-2020 Corded Phone
It currently shows SENT 205V, How do I change it back
  • 3 Answers
This actually happened on another phone also. Somehow, one phone picked up the fact that another phone had new messages saved on it. Thus phone extension 213 had send 222V on this LCD display. Once the messages were cleared off of extension 222, the original display of
CF-BN:213-850 and the DATE below, were displayed. So, I was able to clear it off in the same manner for two other phones. The only thing I don't know is how the voice messaging from one phone was tied into the other.
Posted on Mar 09, 2009
How can a change my apple ID
Firstly, sign out of every apple device linked to your current ID. Next go to the link I've provided at the bottom. Use your current ID to sign in, you may need to enter an authorization code that will be sent to your devices. Once you log in sucessfully you will be brought to a page that will show your current email. You should see a little "edit" link in the top right. You can then add your new email there. After successfully entering it in, apple will send your new email another verification code. Enter that in and you can now use your new email as your apple ID.
https://appleid.apple.com/#!&page=signin
Nov 30, 2016 | Apple Cell Phones
Purple fuzzy bar across center of screen
Bad Vsc voltage. You need to increase it from 205v to 210-215v. Since it's a dangerous place to work, I suggest you to call an qualified tech. The good news is the plasma panel is good.
Nov 17, 2013 | Samsung 58" 1080p Flat-Panel Plasma HDTV
Pressure drops as soon wand trigger is pressed
I would expect it especially if the tip is not on the wand or open to far. It is possible the pump is failing. How much is the pressure dropping, a few pounds I would expect but I am not familiar with that unit.
Sep 18, 2013 | Pumptec Series 205V - 150/M77 Pump - 230...
Can I change the caller ID so it shows on the first ring?
The caller ID information is sent between the first and second rings, so there's no way the receiving phone can display this data on the first ring. You have to wait for the second ring (or just before it).
Jan 15, 2013 | Lucent PARTNER18 Corded Phone
My htc freestyle will not show my sent messages
go to your menu, check messages, then look for sent.
Sep 29, 2012 | HTC Freestyle Smartphone
LG Shine timestamps wrong time
go to phone setting's & change the time zone
Mar 20, 2010 | Cell Phones
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
How do I change the font in "Sent Items"?
Hi there.
You can't change the font in sent items because you already sent email in the font you chose to send them in.
If you send them in large font it should show that in the sent items folder.
Jun 12, 2009 | Microsoft Office Professional 2007 Full...
Want owners manual for 205w nuvi
Hi!
You can get your manual for your Garmin 205v Nuvi here:
http://www.retrevo.com/support/Garmin-205W-GPS-manual
Thank You
Oct 10, 2008 | Garmin GPS
Toshiba DKT-2020 Corded Phone Logo
575 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
