Question about Proform Crosswalk 500 Treadmill
I have an Image 929- 15 yrs old. Has been working great. I have changed the drive motor belt before and it worked fine. Lately the belt is loose with a decent amount of play. I have tried to tighten the platform on both the front adjustment screw as well s the two rear treadmill adjustment screws, no go though it still slows down or stops for a second when you walk on it as it is running. I tried a new belt, buying one an inch smaller to see if this would help- but it did not even fit without prying it on- so I abandoned that idea, Any suggestions ? I am going to go and just buy a new drive train belt today and put it in
  • Anonymous Mar 22, 2014
    when I jog the belt speed changes and then it will stop. Motor belt is tight, motor brushes are okay, walking belt is tight per spec, pick-up is adjusted 1/8, now what?
    Problem Solver:
  • 12 Answers
I would first watch the unit while walking and visably see if the drive belt is slipping or the walking belt is. If neither one seems slipping, it is possible that the torque control on the motor control board is not correct
Gerritt
Serving the Twin Cities
Posted on Mar 13, 2009
I have. Troy bilt snowblower, 3 yrs old and it just stopped moving forward or backward. The blower works and when I start the blower, the propulsion works a little bit then stops. I used yesterdAy and...
check the drive belt from engine to the transmission, sounds loose or even off. If belt and tension are ok check pulley for sheered key or loose coupling
Feb 09, 2013 | Garden
How do u replace broken belt on a white -westinghouse washer new model 3 yrs old
If yours is a 'standard' front loader (you do not say the actual model number) the belt should be easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 15, 2011 | Washing Machines
Washer doesn't spin ; model 3200 bosch; 4 yrs. old; other cycles work
Although all brands are different in design, the basic concept is the same. When a machine won't spin, there are several things to consider:
  • Is the belt broken? Loose?
  • Does the lid switch click when closing? (see video below)
  • Does the spin solenoid engage? (1984 and before)
  • Drive coupling worn out? (on some newer Whirlpool & Kenmore top loaders)
  • Clutch worn out?
  • Current to motor? (Use voltmeter to check)
Dec 03, 2009 | Bosch WFMC 3200 Front Load Washer
Our LSR7233HQ0 washer is 10 yrs. old and the agitator stopped spinning. Any repair tips?
You may have broken the drive belt. Can you hear the motor spinning still? If yes, then it is definitely a broken drive belt.
Oct 25, 2009 | Whirlpool LSR5132PQ Top Load Washer
My YS4500 (3 yrs old) has recently been loosing power in the hydro transmission. The engine runs great, but the drive stinks. I have to ease it into drive and as it gets going it will pick up speed, but if...
Yes, what I believe you have, is a loose drive belt. this can be due to several things,1st, the drive tensioner spring may be broken, 2nd,the drive belt tensioner pivot arm may need lube, or the belt is worn out.
You did not mention the hydro making noise(whining) if that were the case i would have you check to see if the brake were sticking.
Sep 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Washer squeaks really loud while agitating. Drains great 6yr old
Could indeed be the belt or at worst it could be thr main bearing getting dry and gradually seizing up. Hope it,s the belt!!
May 20, 2009 | Washing Machines
Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Mar 23, 2009 | Nordic Track NordicTrack A2350 Pro...
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
Problems with remote start
this sounds more like it is the alternator also check out the drive belt
Jan 09, 2009 | Dodge Caravan Cars & Trucks
Proform Crosswalk 500 Treadmill Logo
310 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Jon Schniers
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
