CODE H5-01 ON SHARP AR-335 how can this be cleared?
  • zpatterson07 Mar 06, 2009
    first you have to remove ALL the paper jams before you start imputting the codes.!!
    on our machine we DON'T HAVE * BUTTON but it worked when i pressed INTERRUPT button
    So the code is P, interrupt , C, interrupt, 14, start , press execute - on screen
    than turn the machine OFF and back ON and code was cleared.
    the icon on the interrupt button looks like two horizontal lines with arrow pointing from right to left between the lines.
    Scholar:
  • 136 Answers
You CAN NOT CLEAR THIS, you have a fuse rpoblem and fuser needs to be repair= yes times like this it is good to relay on service techs to repair this problem, if u r in ct we can help just reply back and leave phone number to calll u back.
Posted on Mar 08, 2009
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
Simulation code for sharp copier ar-m150, diagnosis code list
Press & hold "0" key for total count.
Press "Clear", "Interrupt", "0", "Interrupt".
OR
"Clear, "0", "0", "Clear".
OR
"Clear", "Repeat", "0", "Pause".
Jan 28, 2010 | Sharp AR-5320 Black and White Copier
Ben in het bezit van een Sharp AR-335 machine. Geeft nu de CODE: U2-00 Hoe moet ik handelen om de machine weer normaal te laten functioneren?
Hello sir; You may reset this error code; the procedure as follow;
press"program" "interupt" "clear" "interupt",(interrupt also call pause key),then enter16 press start and clear.
Jan 06, 2010 | Sharp Office Equipment & Supplies
We have a Sharp AR-335 and it is giving an error
on the keyboard near the number pad. "c" is the clear button and I think program is "p" on that machine. Interupt is also up around the key/number pad. Its been a while, but Once you get into the maint/service mode, type in "14" and press the green start key. That will clear up any confusion the machine is havine unless its a fuser or laser code or something on those lines.
May 22, 2009 | Office Equipment & Supplies
We have a Sharp AR-335 and it is giving an error code of H3-00. Any idea what I might do to clear this error?
Hello sir; There is the way to reset;
1, press "program", "interupt", "clear", "interupt'.
2, enter 14 press print.
3,turn power off and back on again.
May 18, 2009 | Sharp Office Equipment & Supplies
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
Sharp Copiers Error code : F1-14
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Mar 02, 2009 | Sharp Office Equipment & Supplies
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
245 people viewed this question
jasbo
jasbo
