Question about Brasstech Drain For Fiat - 239/15S - Satin Nickel
No mileage display
Lcd light on mileage does not work
  • 659 Answers
Your post is in the plumbing section. I think you are having a car issue. You might want to repost your question.
Posted on Mar 21, 2009
Lighting control
You will need to have the mileage meter replaced, it is an LCD display.
Sep 25, 2012 | 2000 Buick Century
On my instrument panel that displays how many miles I have on my truck and what direction I am driving in, it does not light up at night. At night, it displays the mileage and direction, but you can't...
The backlight for the lcd display on the odometer has burned out, it's a common problem on the newer F series trucks.
It's not normally a "serviceable" part, since the backlight is a pair of bulbs soldered into the instrument cluster circuit board. However, if you're confident in your soldering skills, you could replace the bulbs but most people replace the instrument cluster with a working one from another truck (junkyard)
Aug 24, 2011 | 2004 Ford F150
Roadodmeter records mileage , but does not always light up to display the mileage
there is a video on www.fixya.com/cars/t3649175-dash-lights-out that I used to fix my 2002 buick regal I just followed the video directions
Jan 20, 2011 | 2002 Buick Regal
I have a 2005 F150 my dash lights work but not my mileage light dont is there a bulb or no can you please help thanks Tony
If the LCD display is working, and the backlight is the problem, then the bulb needs to be replaced ( bulb just for the LCD display ). F150online has a how to on removing the cluster. Bit long and detailed to cut and paste into a solution here.
Here is a picture of the back, the empty hole on the left is the bulb holder for the message center backlight ( 1/4 turn bulb holder )
If the LCD display is out, then it could be a cold solder joint ( common in the 97-03 MY ) or the pin connector is loose like kredel2000 provided in his solution. Use the How to at the site to remove the cluster, and check the pin connector.
This is a picture of what you would be looking for :
Feb 08, 2010 | 2005 Ford F-150
Radio lights, steering wheel radio controls, and HUD not lighting
well, this morning they are fine, all i did was checked all fuses that had to do with illumination and radio. none were bad so no replacements were made, and now it works. wish i knew what i did.
Dec 08, 2009 | 2002 Audi A6
How to turn off maintenance required light
my mother in law's 2005 Toyota Camry to turn off the maintenance light after an oil change. push and hold the trip/odometer and turn the ignition key to the run position while still holding trip/ odometer switch and release trip/ odometer tun ignition switch off and light should be reset
Nov 15, 2009 | 2009 Toyota Avalon
Display reads oil at 15%
You will have to reset the maintance light. Turn the key in the on position.( Not the crank position ) Push the trip meter button until you see the mileage reading. Now turn key off and with left hand hold in trip button. While holding in the button with left hand turn key to on position until you see dash lights. Hold button in until light starts to blink then after 4 blinks release button for 4 blinks then hold in again until light resets. If it doesn't work try trip A instead of mileage reading.
Apr 27, 2009 | 2006 Honda Accord
Maintainance light says on - 2005 Prius
Try this.. Turn key OFF.. Hold trip/mileage reset button.. While holding button , Switch car on ( but dont start ).. Continue to hold button for @ least 1 min or until ya see XXX's flash in the mileage lcd.. Lemmie know if it works.. I reset hundreds a week and get them confused.. Thanks
Mar 11, 2009 | 2002 Toyota Camry
Reset maint req
Reset - step 1 turn the key to the 'on' position. using the trip meter button, toggle the lcd until 'ODO' is displayed. step 2 turn the key off. now, push and hold the trip meter button. while holding the trip meter button, turn the key to 'on'. step 3 while you continue to hold the trip meter button, you will see on the lcd disply five (5) small dashes and they will begin to 'count down' rather quickly. step 4 continue holding the trip meter button and once all the dashes have been cleared, your lcd will display six zeros (000000) - release the trip meter button now - and then the lcd will display 'ODO' and your current mileage. at this time, your 'maintenance required'/oil change light has been reset.
May 15, 2008 | 2005 Scion tC
My screen lighting seems to be not as bright as it used to be.
I'm going to presume you've gone through all your settings to make sure nothing changed. If you haven't, you can do this by going to 'display' in your control panel.
How long have you had the laptop for? LCD displays unfortunately do fade over time. The life of one is roughly 3-4 years. Lamps can be replaced - I'm not sure if this is cost effective for you, though. Your mileage may vary.
Hope this helps! Good luck.
Apr 08, 2008 | Acer Aspire 5610-4648 Notebook
Brasstech Drain For Fiat - 239/15S - Satin Nickel Logo
126 people viewed this question
Top Brasstech Plumbing Experts
Paul Carew
Tom Chichester
Are you a Brasstech Plumbing Expert? Answer questions, earn points and help others
