Question about Samsung Televison & Video
Keeps saying channel scrambled - Samsung Televison & Video
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem is you might not
have activated to that particular channel.you
get such type of error once the particular channel
is not activated.
check it out..
thank u..
Posted on Mar 06, 2009
  • 10,594 Answers
It looks problem with cable box of cable provider side. you can confirm TV by hooking DVD player and check its picture quality etc.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Provide model number of tv ?
  • 154 Answers
Ok.. explain little more?
    Brigadier General:
  • 3,614 Answers
Better check your cable connection, or better call your cable operator.
let me know
  • micromaster
    micromaster Mar 13, 2009
    have you check your cable connection, or call your cable operator.?
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
It says I need code to get some stationd
This could be caused by your channel receiver picking up a new channel, like a scrambled sky channel.
Do you have a standalone receiver like, MYSky or Free-view, Dish TV or similar.
These usually scan for new channels occasionally and find channels that need codes or are scrambled.
Maybe you have a content lock on the TV to prevent the viewer from accessing some channels.
Feb 11, 2014 | Toshiba 65HM167 65" Projection Television
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
No channels
try factoring settings and then install again...
Jul 03, 2009 | Toshiba 43H72 43" Rear Projection...
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
