I cleaned my he2 plus washer from kenmore and it stopped before it was completed and is now flashing f-26 and will not run. What does this code mean?
Comments:
Mar 06, 2009
- Guru, You fixed my problem and I think you like nothing doing. It went through the diagnostics and it cleared and is now working. My appreciation for the assistance.
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all componets. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem. Let me know how you make out. Catriver
