Home | Canon | Digital Rebel XT / EOS 350D Digital Cam... | Canon Rebel XTI W/s...
Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens
Problem for Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S...
Canon Rebel XTI W/stabilizer lens
By bbridges on Mar 06, 2009
I have a canon rebel xti. I am having a terrible time setting my camera for outside track pictures.Can you tell me the settings I need to use.(Day time and night).I also just purchased a 28-135 stablizer lens.Yesterday my camera kept telling me to change the AF setting....Thanks!!!
Best Solution
posted on Mar 13, 2009
Very Helpful)
sparkysbox
Rank: Guru
Rating: 90%, 41 votes
Hello bbridges,
Wow, you asked a REALLY open ended question. But here is a good starting point for Manual mode shooting.
Daytime (Full Sunlight) ISO: 100 (or 200-400 to capture fast motion)
F-Stop: Depends on how much depth of field (DOF) you want The lower the number, the blurrier the background. The higher the number, the more everything in the frame is in focus. Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Nighttime (Track Lights) ISO: 800-1600 F-stop: Again, depends on how much DOF you want Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Remember when you are panning to capture something in motion, keep on tracking (moving with the subject) even after you have released the shutter. It will help your stability reduce the chances of unintentional blurring.
My suggestion is to go to dpreview.com or stevesdigicams.com and do some rooting around in the forums. They both offer friendly and helpful advice. Also, check out webphotoschool.com
Better yet, experiment with your camera. Pick a time of day and take a series of photos of the same thing, and only change one setting at a time. Make note of what photo number you're on, and what setting you changed (and what it is). Then, when you look at the photos on your computer, match the photo numbers up with the chart you've made, and you'll begin to see a pattern. This is one of the faster ways to learn by trial-and-error. And, this method sure beats randomly shooting and just spinning the dials hoping to get something good. Try to predict the outcome of the shot before you shoot it. Ask yourself what the photo should look like (light? dark? just right? everything in focus, or just the subject?)
As for your lens, check to make sure the Auto Focus settings in your camera menu as well as on the camera are set correctly. And if all else fails, turn off the camera, remove the battery, remove the lens (in as dust-free environment as possible), and then put the lens back on, the battery back in, and turn the camera on again.
Happy shooting, and hope this helps!
**If this response helped you, please take a moment to rate it — thanks!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 30, 2009
Not Rated)
chrisgreensk
Rank: Apprentice
Rating: 0%, 0 votes
try changing the aperature and shutter speeds between the two you should be able to find a setting that shoot great outside photos
Was this helpful?
Yes
No
Popular Solutions for Canon Digital Rebel XT / EOS
Questions and Unsolved Problems for Canon Digital Rebel XT / EOS
Do you recommend Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens?
Answer
Answer
I hve been offered an unused Canon 5D Mark II body only for $1500, serial number 1120704112. As... (More)
Answer
Auto-focus feature under exposes/overexposes. Obviously not metering correctly.
Answer
i havnt got disk for my canon eos 350 how do i put pics onto laptop
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon Digital Rebel XT / EOS...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
