Question about Honeywell HFD-130 Air Purifier
Question Is the ionic breeze quatra safe or not?
    President:
  • 389 Answers
Presumably it meets all relevant safety standards, otherwise it would not be permitted to be on the market in most civilized countries.  That said, it certainly produces ozone which, while a highly effective odor destroyer, is an environmental pollutant and causes upper respiratory tract irritation and other symptoms (check out ozone in wikipedia, and you won't want to be around it for long!).
Personally, writing as a qualified chemist and biologist, I would not want to be in the same room as a working ozone generator.
Does that help?
Posted on Mar 07, 2009
My ionic breeze quadra air purifier keeps turning on and off. I have cleaned the fins, what else can i do?
Hi.
The filter will probably need replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 08, 2010 | Sharper Image Professional Plus Ionic...
My Quadra Ionic Breeze, has a small glowing fire within it at the base. There is a smell of plastic/electric burn. Though the odor did cover the odors in my house, I think I have a fire hazzard on my...
the ionic breeze uses high voltage to move/filter air .. if the insulators break down there will be an arc such as what you see .. there is a way to dig out the carbonized material and seal it with materials that can handle the high voltage but any repairs are costly .. its unlikely you can repair it for less than a new conventional filter .. the ionic breeze was unique and expensive but didn't move a lot of air ..it was quiet but often produced some ozone .. long exposure to ozone is not a good thing .. here is a site where you can learn more about your unit
http://en.wikipedia.org/wiki/Air_ioniser
check out where it says "Consumer Reports court case" ... that said, the electrostatic concept does probably remove small particles that are hard to do with conventional filters .. the arcing you see in your unit is indeed not safe . ... here is more that you likely don't want to hear..
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
in the next one look down where it says "Ionic breeze" under "helpful information" that will frost the cake
http://www.sharperimage.com/Pages/Helpful+Information/#ionic_breeze
i am sorry to say that your expensive ionic breeze is not safe and not repairable.
Aug 15, 2010 | Sharper Image Professional Plus Ionic...
Unit will sometimes make a crackling noise.
Mine does it too, I finally just tried something else when I was cleaning the blades. I took some alcohol on a qtip and with the blades out of the machine I wiped up and down the line wires that are inside that go from the top to the bottom, and also the little balls that are on the bottom of the wires that slide when you turn your unit upside down. It seems to work, I do it every time I clean the blades. scribner062
May 22, 2010 | Sharper Image Ionic Breeze Quadra Air...
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Regards.
Ginko.
Mar 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze is arcing after it was cleaned. Let
sharper image has a class action lawsuit against them for the ionic breeze you should look into it
Dec 03, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
How do you reset a Quadra ,Ionic Breeze
Hi.
This appliance simply resets by disconnecting the power cord for five minutes. The control board does not include battery.
If the model was manufactured before 2007, pleas read below.
Ionic Breeze Concerns
Regards.
Ginko.
Nov 14, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze Quatra
Check online to see if you can purchase just the replacement parts and fix it yourself. Chances are, however, you might be forced to send it to the manufacturer to get it repaired.
Check your local stores (WalMart, Target, etc) in the luggage area and get one of those power converters that you use when you travel to a different country. I wouldnt leave home without it. it pays for itself when you consider how much stuff you can literally destroy and cook off because the voltage is different than what it is here in the USA.
Jul 22, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Honeywell HFD-130 Air Purifier Logo
155 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
