Question about Panasonic CT-36SX31 36" TV
TV decides to turn itself off now and then. A slap on its side restores power....for awhile. Sometimes, it turns itself back on w/o a slap. It's a good TV and want to keep it. How repair intermittent power loss?
    Genius:
  • Panasonic Master
  • 1,550 Answers
You need to check all the cracked solder joints and resolder him
Posted on Mar 06, 2009
Tv turns itself off but power light is still on
Check for any loose contacts at the power plug point. If mains power inerruption takes place, this kind of fault can occur.
Jun 20, 2013 | Televison & Video
I have a hitachi p50x01au plasma and I was just watching tv and it turned off by itself.I tried to turn it back on and all I get is a green blinking light.Do I need to call a technician?
you need to unplug power cord from back of tv and let it set for awhile then plug back into the back of the tv i also have a plasma and it sometimes does that also
Jan 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
My tv decides after being on for a while that it will turn itself off and wont turn back on for awhile. What causes this?
Your STK ICs could be the cause or alot of poor solder joints, But I would replace Both of your STKs they are big black ICs will have part number on them example STK392-570 Its just a matter of time TV will not come back on at all. for parts call Mats 1-800-628-1118
Dec 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I also have an AKAI LCT3201AD that keeps turning off.
Bad power supply circuit....
Bad resistors, rectifiers, capacitors, or MOSFET devices. Your tv needs to be serviced, and for this problem it should be to expensive and should be 'sameday return. Its an easy fix.
Jun 12, 2009 | Akai LCT3215/26 32 in. LCD Television
Picture is really light in color screen is white
It sounds like you have bad solder joints in the tv. If you resolder the boards in the tv, it sounds like it will be fine. When you are slapping the tv, it is temproarly making contact again and fixing the picture..
Jan 02, 2009 | Mitsubishi VS-45607 45" Rear Projection...
WHY DOES MY TV TURN OFF BY ITSELF AND WON'T TURN ON FOR AWHILE?
There is 2 reasons for this poor solder on power AC board and a capacitor going bad. cap when failing will puff up on top.
Nov 29, 2008 | Akai PT4799HD Rear Projection Television
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Sharp LC-30HV4U
I have the same problem with Sharp LC45GD4U intermittant turn off by itself ,somedays working OK..
Thanks.
Tanvo
Aug 26, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Mitsubishi WS48511 TV will not power on completely.
have you checked the pico fuses on the bottom side of the PC board? They are small ceramic fuses soldered directly to the runners.They have been known to blow and your set will not power up. Hope this helps, if you need anything further let me know. Also sometimes the 1000uf caps don't show any signs of swelling but can still be bad.
Jan 23, 2008 | Mitsubishi WS48511 48" Rear Projection...
Open Questions:
Panasonic CT-36SX31 36" TV Logo
155 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
