Question about Dell Inspiron B130 Notebook
My laptop (Inspirion B13) speakers work
I have the same model and problem. I noticed that audio gets choppy and cuts out the same time the hard drive light is on. The less the light is on, the better the audio quality. I downloaded and installed the latest drivers as suggested, rebooted, and still have the problem, so it must be the hardware.
  • 2 more comments
  • coffelta Mar 06, 2009
    I installed the Sigmatel audio driver offered from Dell's website for this model. There's only one driver available. I assume the sound card on this model is on the system board and can't be replaced. If it needs another driver, where would I get it?
    No, it's not under warranty. Other options?
    It has the latest BIOS and the system was recently wiped and the OS (XP) installed fresh.
  • coffelta Mar 07, 2009
    This makes the most sense of all the suggestions.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Does the same problem happens when the unit is running with the AC adapter plugged in and charging? Or, pls try with the AC adapter/charging.
Offhand, it could be a battery issue or (most likely) an internal power distribution issue. I am tempted to suspect that the audio circuitry is not getting sufficient power when the hard drive motor accessed. Should this be the case, then it would be the system board since the regulator circuitries are built-in to it.
Pls postback results.
Good luck and thank you for using FixYa.
Posted on Mar 06, 2009
    Scholar:
  • 67 Answers
This is because your Hard Disk Drive (HDD) is set to Programmed Input/Output (PIO) mode. Your HDD should be running in Direct Memory Access (DMA) mode. To correct this, follow these steps:
  1. Go to the control panel with Start -> Control Panel,
  2. Double-click on the "System" icon (minus quotes).
  3. Go to the "Hardware" tab (minus quotes).
  4. Click the Device Manager button.
  5. Locate the "IDE ATA/ATAPI controllers".
  6. Right click the "Primary IDE Controller".
  7. Choose properties
  8. Click the "Advanced Settings Tab"
  9. If Device 0 and Device 1 mention "PIO Only" for the Device Type, you need to change the Transfer Mode to "DMA if available".
  10. Do this for both devices and when it asks you if you want to restart (if it does, I can't remember), select no.
  11. Repeat steps 6 throgh 10 replacing "Primary IDE Channel" with "Secondary IDE Channel".
  12. Now right click everything under the "IDE ATA/ATAPI controllers" and choose uninstall. Uninstall it all but don't worry, the PC will reinstall it all when you reboot.
  13. When prompted each time, to reboot, select no at this time.
  14. Once all the controllers are uninstalled, reboot the PC.
When the PC boots again, log back into your PC and wait. It's going to pop up "New Hardware Found" info down in the corner. This might take a while. Wait until it stops displaying those icons before you restart the PC. Eventually it's going to say you need to restart your PC for these changes to take effect. Select NO to the first ones and ensure it has installed all of them by checking the Device Manager again. Remember, to get here its Start -> Control Panel -> System -> Hardware -> Device Manager -> IDE ATA/ATAPI controllers. If it looks like it has installed them all, restart the PC.
Once booted, head back to the Device Manager again and check the Primary and Secondary IDE Channel and ensure both are running in "DMA if available".
  • Matt H
    Matt H Mar 06, 2009
    FYI, PIO mode is a severe bottle-neck for PC traffic. It passes information from devices through your CPU which elevates the CPU usage and can cause shuddering in video and sound.
  • Matt H
    Matt H Mar 06, 2009
    Coffelta,
    My solution will fix your problem.
    Master:
  • 763 Answers
Im not so sure problem is in the hardware but it could possibly be. you should send it to repair service for checking the whole laptop. another is you can buy an external sound card to check what really the problem is. Like, sound card or the speaker or the driver itself. with the use of a new sound card you can distinguish what or where cause the problem.
thank you for using fixya
CHARCOIS
    Genius:
  • 1,550 Answers
It tends to be hardware problem in your system . There will be a cable inside the laptop which needs to be replaced . It connects the speaker to the power button and you face this problem due to improper power supply to speaker .
You need to dismantle your laptop to work on this problem.
You should have service manual inorder to help in proper connection .
Hope this helps.
  • 6,784 Answers
Yes, this sounds like an operating system issue. i suggest preforming a complete restoration of the entire OS. this will fix the choppy nature of the sound. A bios update is needed as well.
  • Michael Masters
    Michael Masters Mar 06, 2009
    Ok, you mentioned that you have reinstalled windows and the bios has been refreshed. this leads me to believe that this is a manufacturing flaw that resides within the motherboard. i suggest returning this laptop for an exchange. this is a defective model.
    Brigadier General:
  • 3,614 Answers
You must first completely uninstall the device driver on your laptop,
reboot the unit, and let it detect the device that need to be reinstalled the driver,
let me know
  • micromaster
    micromaster Mar 06, 2009
    also:
    What OS Operating System you are using.
    Since when you encounter this problem, is there any related problems before the problem appear.?
  • micromaster
    on what specific Application you are using that the audio will begun choppy..?
    Kindly specify and detail it to us..
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem may be due to
the C-media PCI soundcard.
check it out..
thank u..
  • Hariharanath V Mar 06, 2009
    hi..you have to go to the nearby computer shop.
    try this out..
    thanks..
  • 10,594 Answers
Seems hardware problem, please check is it still under warranty then ask Dell for exchange the notebook.
  • Shahid Electronics
    Shahid Electronics Mar 06, 2009
    local computer repair shop is your next option.
  • 154 Answers
It seems that the driver is not compitible with  the operating systm. you need another driver.
  • crysiszone Mar 06, 2009
    if you install the latest driver, than its better to try a new card.
Choppy rear audio
I'm not sure what you mean by "choppy rear audio". Do you mean the sound is distorted? Can you please explain as well as provide your make and model number.
Thank you.
Apr 24, 2014 | Audio Players & Recorders
Dell laptop HD
This model laptop came with a 60Gb hard drive and it will work with a 40Gb hard drive.
If it was me I would install a 60 Gb hard drive not a smaller one.
Apr 30, 2013 | Dell Inspiron Computers & Internet
Choppy video and sluggish computer response
How much HD space do you have left? Most macs run best if you keep abou 10gb of HD space free. Furthermore, cut back on excessive app loads (bells and whistles. The ultimate solution is to back up your files and reinstall the mac os. If the problem persists it is possible that the CPU is starting to break down. This is replaceable at significant cost from mac repair shop. Maximizing RAM helps some, but age of the equipment will reduce performance.
Aug 09, 2009 | Apple Computers & Internet
Choppy audio on Sansa e260.
To me it seems like the head phone jack is loose, it might need to be re soldered and then things would be back to normal. HOpe this works.
Wayne
Jun 26, 2009 | SanDisk Sansa e260 MP3 Player
My laptop (Inspirion B13) speakers work sporatically (sound is scratchy as it seems to be skiping) when I play DVSs. How do I fix this so I can have clear sound?
Hopefully it's a software problem and not hardware. I'd start by downloading and installing the latest drivers from Dell. Here's a link to the support site:
http://supportapj.dell.com/support/downloads/index.aspx?c=in&l=en&s=gen
If that doesn't work then it's probably a hardware problem. Let me know if the first suggestion works, otherwise I'll post other tips.
Feb 22, 2009 | Dell Inspiron B130 Notebook
Choppy sound and video on laptop
Unfortunately your video card memory is probably lacking. And/or your settings are set too high for your processor to handle. Right click on your desktop, goto properties, goto settings, and select for best perfomance then apply.
CD's play simple audio files. DVD's and games play large video files and large audio files that are choppy on older systems. you may need to upgrade your memory. Make sure you delete all you dont use, run disk cleanup. REstart. Run, disk defrag, Restart.
A good test is goto : www.belarc.com or belarcadvisor.com
They will tell you if yoursystem is uptodate.
You may just be running a older processor?
Let me konw,
Mark
Dec 29, 2008 | Dell Inspiron 1501 Notebook
Audio Troubles
hi!!!!
there was a corrupted file in your windows registry or in windows system 32
the solution for that is to reformat your operating system
back up all your important files!
Sep 18, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Audio drivers
Check the manufacturer website on your manual and browse their web for dowloading the Audio driver and follow the instruction to install it on C:\ (hard disk). simple reach me later that solve your problem.
Sep 15, 2008 | Systemax Pursuit 4100 B13 Notebook
Audio running choppy
uninstall the audio driver and re-install it. it will work fine
Jul 19, 2008 | HP Compaq Presario V2000 Notebook
Windows vista home premium voice problems
TRY THIS http://www.bytescribe.com/downloads/tsp_codec_install.exe
Aug 28, 2007 | Logitech 250 Headset
Dell Inspiron B130 Notebook Logo
22 people viewed this question
Alun Cox
