Question about Kenmore Washing Machines
When I put cycle on Hot water nothing comes out
Cycle will work on cold water but not hot
    Problem Solver:
  • 18 Answers
Water valve
Posted on Mar 06, 2009
Cold water setting not working-only hot comes out
The cold cycle begins with hot water to dissolve powder detergent regardless of whether you are using powder or liquid.
Jul 27, 2016 | Whirlpool Washing Machines
No hot water
The replacement valves could be defective or installed incorrectly.
Nov 15, 2013 | Maytag Neptune MAH5500B Front Load Washer
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Anyone anygood troubleshooting a Whirlpool Washer?
Thats a problem. Did you have the washer laid on it's side when moving? Timer switch would be first look. Hot water not working,but cold is? Mmmm.. Water inlet is pretty simple no real mechanical parts except intake valve for each inlet. Valve could be plugged or stuck closed on hot intake. Temp switch could be bad and that would cause the water intake to shut.I guess, but not usually a problem unless old machine. Make sure the fuse in control panel is intact. Underside of washer is a relay switch called wigwag. If it is bad nothing will cycle, easy fix 10 minutes and $15 in most cases. But check out before jumping to solve. All ways check cheapest parts first. Lid switch would also cause the no start and spin cycle problems.
Mar 09, 2010 | Washing Machines
Cold water cycle doesnt work, no cold water at all, just hot
Could be the cold water solenoid is stuck or broken, maybe a wire has broken or terminal worked loose.
You need to take a look inside and check the wiring, check the supply to the solenoid, etc. If the supply is good the solenoid is probably faulty. If there is no supply it is possibly the board or the controller.
Jun 18, 2017 | Maytag Legacy Series Top Load Washer
Cold water knob is not working
Check the screen on the cold valve. If power is getting to the valve and the screens are clean then the coil is bad. Check continuity if you have a meter.
eric
Jul 01, 2009 | Washing Machines
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
65 people viewed this question
Sal De
fordexpert
Robert Rankin
