Question about Kenmore 22422 Top Load Washer
Kenmore 80 series spins but won't ring out clothes
I have a Kenmore 80 series top loading washer. It may do fine for a wash or two then all of a sudden, it won't ring out the clothes. It is spinning but won't ring the clothes out. For instance, I just washed a bathroom rug and my washer won't ring it out on any of the spin cycles (delicate, normal or heavy). This has also happened here or there with various sized loads. We've recently moved and the wierd thing is that this didn't start until we moved... what could be the problem???
  • dansgirl_10 Mar 06, 2009
    Thank you so much. I will check out all of those things. Actually, the home we've recently moved to has very hard water and one of the characteristics (I am told) is that soap tends to curd up. We have recently purchased a water softener for the home and hope to get it installed this weekend... hopefully that will solve our problem. Thanks
  • 283 Answers
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Posted on Mar 06, 2009
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer top load
Sounds like the clutch/brake assembly is slipping.
Feb 17, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
467 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
