Question about Olympia - 1452C CROSS CUT OFFICE SHREDDER
Olympia Shredder Jammed and not working
I shredded for about 5~10mintues. Last shred was 5 pieces of a4 paper and suddenly the shredder jammed with loud noise. Now the shredder can move forward and reverse alittle as though jammed in between. What can i do?
  • 469 Answers
Likely a spacer has broken, if you can see the underside of the cutting heads you will see a spacer or two hanging out, If this is the case the heads will have to be bebuilt or replaced.
Posted on Apr 15, 2009
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
Qualcast manuals
Unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 25, 2014 | Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Jammed shredder
If your Ativa shredder has a bin, you can gain access to the shredding mechanism by removing the bin and turning the shredder upside down. With power disconnected, be prepared to spend considerable time picking out bits and pieces of material. Tweezers and a utility knife are useful tools. Eventually your shredder will be back in working order.
Feb 28, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Paper shredder jammed
Yes....this is a consumer model....NO BIN/BAG FULL INDICATOR....to keep costs down, you will just have to try to get the bin out a little at a time and slowly reach-in and "fish out the shredded paper...once you have enough out the bin will come out...hopefully the backed up paper has not jammed the machine and blown the PCB inside.....if it has give Royal a call at 1-800-524-0799 for parts assistance.
May 01, 2010 | Royal 150MX Cross-Cut Shredder
Shredder is jammed
hello. follow these steps:
  1. Turn the shredder off at the wall and unplug it. You DO NOT want to be poking round in those sharp blades and have it accidentally switch on!
  2. Take the top off the shredder and place it on a big piece of newspaper, or somewhere you can easily sweep up mess.
  3. Begin by getting a pair of tweezers and taking pieces of paper from one end of the shredding blades. This will loosen it up and give you more room to get the rest out.
  4. Carry on tugging the strips of paper out. It helps if you don't just pull a clump, but wiggle it from side to side. This will get the whole strip out, not just the top.
  5. If any pieces are curled round and you can't free them, cut them with the knife and then tug them out.
  6. Once it's mostly cleared, put the top back on and switch the shredder on. Put it on Reverse mode so it will spit the last bits back up for you to remove.
  7. If it's clear, continue shredding!
[edit] Tips
  • Remember to wiggle the paper, not just pull.
  • Shake it occasionally to get smaller pieces of paper out of the blades.
  • Try not to jam it in the first place (avoid loading a lot of paper or thick sheets of newspaper).
  • Use oil paper or performance oil to lubricate the blades on a regular basis. For an office shredder, medium to heavy usage can require lubrication as often as every three days.
  • To prevent the shredder blades from dulling, remove paper clips and staples before shredding. Shredding CDs and DVDs also cause premature wear & tear. Use the Disc Eraser (www.DiscEraser.com) if you have sensitive discs.
[edit] Warnings
  • Always turn the shredder off at the wall and unplug it! You don't want shredded fingers!
  • Be careful with the blades - they are sharp and you could cut yourself.
[edit] Things You'll Need
  • A pair of tweezers
  • A small, sharp knife
Oct 23, 2009 | Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
194 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
