NEC Dsx 22b Display Tel bk Dx7na-22btxh Tel bk Black Logo
Anonymous Posted on Apr 05, 2013
Phone won't ring
Phone will not ring when receiving a call, and it will no longer pick up a call when the phone is picked up, we must select a line
  • Anonymous Apr 18, 2013
    thanks so much!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
567
Points
While the phone is hung up, press #725. Then press any line button that isn't solid green until it is. You just have to cycle to "Always"
worldhound
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Apr 05, 2013
worldhound
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
1961
Points
25
You will need a telephone specialist. Issue is likely in the hardware installed on location.
The issue may also be in the programming. (If someone has been trying to make changes to the phone system)
My Norstar Phone Won't Let Me Pick Up Incoming Calls
Make sure they are Line Buttons, do FEATURE * 0 then press buttons to see what they are/do
Or maybe the key pad inside has failed.
FO-3150-won't auto answer, have to pick up receiver to get faxes
renield, that worked perfect!!! Thanks a million!
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Fax won't answer
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
1helpful
Answerphone Question
Push Menu, Scroll to Initial Setting and push Select, go to Set Answering and push select, go to Ring Count and push select, you should be able to scroll up or down to the number of rings, in your case 6, and then push save
My answering machine pickes up after the second ring. How do I get it to ring longer before picking up?
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
4helpful
2answers
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Brother MFC 885 CW answering service malfunction
It was all a matter of pressing down the Digital TAD button down hard enough... o-:
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
