It turns on and shuts off.
For my YAMAHA RX-V795a, Replaced the relay DG1U, which is controlled by the on/off button. Because the switching contacts in the relay were burned in. (Relay of which you hear the click when you switch on or off)
And everything works again. But replacing it is a bit of work...
You have to, after opening the case, among other things, loosen the screws of the main transformer and some more things, to be able to turn over the PCB on which the relay sits, to loosen the 4 solder points of the relay.
The relay is Type DG1U, 12VDC coil , switching contacts 8A 250V AC and is a Chinese brand DEC.
They are sold by Aliexpress, among others.
