Question about HP DeskJet 895cse InkJet Printer
Fixed a paper jam, printer started to print one line
I fixed a paper jam, and the printer started to print one line characters and kept on printing on one page for about 30 or more pages! Then it started to print the page I needed! I need help!!
    New Friend:
  • 52 Answers
When the printer jamed and you had to pull out the jam, the data being tranfered for that job got out of sequence. On Deskjets when that happens, you need to go to the print spooler and delete the job it is printing or you will have the same problem evertime.
Posted on Mar 06, 2009
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
How do I fix a paper jam in a Brother MFC-7860dw printer?
Try resetting the printer.
~Menu
~4. Printer
~4. Reset Printer
Jul 02, 2012 | Brother MFC7860DW AllInOne Laser Printer
Printer D2460 blinks not print
The HP printer may print incomplete characters. This issue occurs due to clogging of print heads. So this problem can be solved by cleaning or replacing the print heads. Sometimes the printer will not accept the paper tray. At that time, you have to turn off your printer and disconnect the printer from its power source and reconnect the power and then turn the printer on. The printed pages will sometimes come out skewed, this may be due to curled or torn paper become jammed inside the printer. One easy remedy for this problem is that, you have to remove the torn pages from the paper tray and smooth down all the curled edges of the paper. If the settings of the printer are not correct or the paper tray is overloaded, the printer may pick multiple pages for printing, which could result in paper jam.
Get more help to fix HP Printer Not Printing error. Hope this helps you.
Jul 04, 2011 | HP Deskjet 2460 InkJet Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Paper jam
First when you see that first page come out like that...turn the printer off. You will need to re-install the printers drivers. (the CD that came with the printer)
Sep 20, 2007 | HP DeskJet 920c InkJet Printer
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
HP DeskJet 895cse InkJet Printer Logo
207 people viewed this question
Ben Johnson
