Question about KitchenAid K45SS Classic Stand Mixer
MOTOR SPINS ON MY CLASSIC STAND MIXER BUT GEARS DON'T ENGAGE
THE MOTOR ON MY STAND MIXER SPINS AND SEEMS TO BE AT THE PROPER SPEEDS BUT THE GEARS DON'T ENGAGE AT 10 IT SEEMS TO WANT TO GO BUT YOU CAN STOP THE MIXER BY HAND This mixer is only 2 and a 1/2 years old no problems or noises previously
  • 1 more comment
  • korongo Mar 17, 2009
    my motor runs but the rotor does not turn & makes tak tak noise. please help
  • Anonymous Mar 28, 2009
    The motor runs but the beater shaft or the beater do not turn around/spin.
  • Rick Belanger
    Rick Belanger May 11, 2010
    Hi. Were you making bread dough or cookie dough at the time it broke? Did you hear a CRACK when the mixer failed?
    ricardok45
  • 135 Answers
Hi all. There is damage to the transmission caused by overloading the mixer with bread or cookie dough, or by dropping a spoon or measuring cup into the mixer while it was working.
Go to mendingshed.com and download their free kitchenaid repair manual. This manual has all you, or a repair person will need to repair your model's mixer. Mending Shed also sells needed parts.
If this solution has assisted you, please rate it. ricardok45
Posted on Apr 07, 2009
My kitchen-aid stand mixer won't spin when turned off. When on and mixing, the motor starts to "dog", or slow down, when it's mixing something as easy as cookie dough.
If the motor itself is slowing down, that is one thing. However, if you mean by "dog" that there is what sounds as if a gear is slipping then the solution is straight forward. The worm (follower) gear needs to be replaced.
There are videos on the net which show how to do this and the Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 21, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid motor slows
If it slows down when mixing, it is most likely that the mixer is being asked to do more than it is capable of. If it slows down when nothing is in the bowl, then the motor/gears/lubrication needs looking after.
The Service Manual is at:
Dec 15, 2013 | KitchenAid K45SS Classic Stand Mixer
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
My stand mixer's motor runs but the blades don't turn to mix the food
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
The Worm Gear (12) teeth was stripped and needs to be replaced.
The whole Worm Gear Assembly can be purchased on eBay for under
$15.00
Aug 04, 2011 | KitchenAid K45SS Classic Stand Mixer
The motor works fine and you can hear it engage as you change it from speed to speed but the the beaters do not turn
This sound like the worm gear has failed: http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
You will need to take the mixer apart to confirm this.
Jan 23, 2010 | KitchenAid K45SS Classic Stand Mixer
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
My Kitchen Aid mixer attachement rod won't spin when turned on.
It sounds likme you may have stripped/broken one of the gears up in the mixer head. Any competent appliance repair shop should be able to fix it.
Jan 02, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
346 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
