Question about Graco Quattro Tour Deluxe Travel System 7B00GRM3 Graham
How do you lay the seat back to the flat position?
In the rear of the pushchair halfway down is a thin steel handle. Pull this towards you and apply downwards pressure. This allows the pushchair to fold back down and become a pram..
Posted on Mar 07, 2009
How do I pull down the back seats so it lays flat
My 2005 Santa Fe back seat does NOT LAY ABSOLUTELY FLAT. It stays at a slight angle when I configure the rear area for cargo.
Oct 16, 2014 | 2005 Hyundai Santa Fe
1990 Park Ave drivers seat recliner motor
You must remove the motor, move the seat to the desired position and then reinstall the motor to lock the seat in the position.
Sep 10, 2012 | Cars & Trucks
I have assembled my Peg Perego Pliko switch, but cannot make the back of the bassinett to lay flat. It bends as though it needs to snap in. Is this normal or does it indeed snap flat? Thank you in...
If you talking about the bend/hump in the middle of the seat, top to bottom, I haven't gotten mine (2009 model) to lay flat either unless my daughter is in it. But the back rest does lay completely flat and she's been able to nap in it. As long as the seat is correctly attached at the sides near the "handle bars" and corresponding dots, it should be safe to use.
Nov 03, 2010 | Peg Perego Pliko Switch Classico Java...
Stanley 10-777 utility knife: I need to reinsert the retractable blade slide back into the knife body. I try but the knife won't close.
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Oct 27, 2009 | Stanley Hand Tools
How to fit carry cot to car
I assume you are referring to the Matrix Pro Car Seat that lays flat? You can fit this in two different ways. To fit it sitting upright, make sure it is in the most upright position and facing the back of the car. Pass the lap belt underneath the car seat itself, through the blue catches, then plug it in. The long part of the seat belt goes around the back of the car seat through the blue catch nearest you. Pull it all really tight and it should be more secure. To fit the car seat laying flat, this depends on your car. It needs to use two 3 point seat belts. 2 point seat belts don't work. Plug in both seat belts, and pull the lap belt part through the silver catch on both side. Pull as tight as you can. To make car seat fitting more secure, try placing a slip mat like the Sunshine Kids Grip It or Super Mat underneath to hold it in place. These are all crash tested and safe.
Sep 12, 2009 | Baby Gear
Can the jane matrix car seat be used in the up right position from birth or is it only meant to be used flat. The upright position seems too upright and my baby seems in a very uncomfortable squashed...
Yes, this seat is designed for newborns, but you are correct as this does look a rather acute angle. If you use the lay flat option for a few weeks until baby's head can support a little better, this is often the best option. Please note that the lay flat option can only be used until 10kg.
I hope this helps.
Jun 20, 2009 | Baby Gear
Hai i would like to know how to fold the back car seat to increase cargo space in hyundai santa fe 2003
The rear seats have a pull strap located between the bottom cushion and the backrest of the rear seats used to disengage a lock to lift up the bottom cushion. The pull straps will only stick out an inch or so, or they might have fallen down between the seats and then you wont see them. Before you can lower the backrest of the rear seats, the bottom cushions have to be lifted up and forward out of the way so that the backrest may lie down flat. If your pull straps are not visible between the bottom cushion and the backrest, you may have to stick your hand between the cushions and feel for the straps. Once you find the straps, pull upward on the while lifting on the bottom cushion where the pull strap is located and the seat should tilt forward. Once you have manged to do this, the lever for the backrest is located on the top of the backrest. Just slide the lever and tilt the backrest to the desired position.
Apr 13, 2009 | 2003 Hyundai Santa Fe
Lost my manual. How do I remove the middle seats?
First, fold the seat all the way until it lays flat on itself, use the side lever or pull the strap from the back. This will release the seat back, now tilt the seat forward raising the rear part of it, make sure that there is enough space with the front seats to allow it to go all the way until the top part of the seat touches the floor, in this position pull the black strap you will find underneath the seat cushion. This should release the seat, now you can tilt it back and should be able to get it out.
Feb 28, 2009 | 2008 Toyota Sienna
Button to lay evenflo stroller down
I own two evenflo strollers- from the pictures I believe it's the same exact stroller. Mine don't have "buttons" to lay down the seat.. instead they have a "cord" like a belt in the back towards the top- you can let some out to lay the seat down- or else pull it tight and it will 'raise' the seat to a sitting position! The 'belt/rope" for adjusting has a D-ring on the end of it- so look for that towards the top center in the back (under the handle bar).
Dec 27, 2007 | Evenflo Aura 3s Co Stroller
Need to recline seat
On the back of the the seat back is a plastic tab connecting two lanyards/cords. These cords are used to adjust the seatback angle from the recline to full up-right position.
Nov 01, 2007 | Eddie Bauer C01078EBL Light Weight...
Graco Quattro Tour Deluxe Travel System 7B00GRM3 Graham Logo
357 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
