Question about Emerson NR303TT CD Shelf System
Putting a needle in my nr303tt
I just bought a nr303tt and it didn't come with a needle. I have some extra needles from an old record player I had prior to this one, but I can't figure out how to put one in.The arm only lifts an inch, so how do you work on it?
Thank You, Tim
  • 3 Answers
The needle should slide on and off. you should consult your owners manual or if you do not have one, you can download and print one from the emerson web site.
Replacment needles can be purchaced from the only authorized distributor of emerson parts(Fox International LTD. , Inc.) (800) 321-6993. Don't forget to provide your model number.
Posted on Jun 15, 2011
I have an electro brand 9249 record player. How do I remove the needle and where do I get a new needle
Hello
The needle and cartridge can be bought from most of the standard electronic sparepart selleing shops at your town. It will be best to replace the cartridge along with needle. Cartridge will have a number printed on it, should be noted. OK.
Jan 03, 2012 | Electro Brand Nostalgic Stereo CD Music...
Record player sounds scratchy and tinny
Playing records is a contact sport.
Since the needle touches the record -- as opposed to a laser reading a CD -- any bit of dust or mold translates to annoying pops and hisses.
Record cleaners get down into the record grooves to extract dust and particles.
Or you may need a new needle.
Mar 25, 2009 | Electro Brand Nostalgic Stereo CD Music...
Need pick-up needle for old type record player.
you can replace with mmc4000 mmc20s mmc20e mmc20en if you can find one,been discontinued for a long time.
Jan 11, 2009 | Bang and Olufsen Beosound 2000 Shelf...
The record player skips
Hi There,
From your description it sounds like there is insufficient weight on the needle end of the pick up arm.
The pickup arm is very delicate in its balance at the "rear arm end" fulcrum.
This weight is adjustable to allow the needle to press on the music track to an exact pressure and it is adjustable so that this pressure does not damage the music track.
There should be a wheel type thingy at the rear end of the pickup arm.
This wheel is usually marked in Grams, and to make the needle end heavier to stop "skipping' you turn the wheel to wards the + sign.
This + sign means more weight on the needle.
There also should be a - sign, and the wheel, when turned in that direction, the weight on the needle is reduced.
You need to be aware that a needle really needs to exist in the cartridge as they can be broken off very easily and if there is no needle present there, then there is no way you will get any music from the turntable.
So check there really is a needle there...use a magnifying glass to see....
If thats OK then place the needle end of the pickup arm on to the record surface and turn the weight wheel until the needle just lifts from the record surtface.
Now that this stage has been received turn the weight wheel in the reverse direction by around 5-7 grams in the heavy + direction.
The needle should now be resting on the records surface and not lifting at all.
It should play like this,,,BUT please ensure the record player is on a perfectly flat surface the
needle wont work on any incline at all...
If you turn the amp on in the phono switch position and carefully hold the needle over the record and touch the needle with your finger you should get a scratchy sound from the speakers.....
This is a basic test to ensure the amplifier and all the wiring is in place and doing its job..
Im Sorry you had a run around from the repair company but some of them are not interested in repair work any more they just want to sell new hardware...
It pays to ask if they are Pepared to repair stuff for you , then get a commitment of a reasonable repair date and time in writing.
If this date and time is exceeded then you dont have to pay for the repairs do you??
As they have missed the service level agreement you had with them for the reapir date and time..
Hope this helps
From
YUBEUT..
Aug 13, 2008 | Teac GF-350 CD Shelf System
Record Player won't spin
it helped enough. it gave us an idea of what was wrong. thank you. :-)
Jun 17, 2008 | Crosley CELEBRITY ENTERTAINMENT CENTER...
Technics SL-1350 Direct Drive Turntable
Hi
Check that the cuing lift isn't touching the arm as it gets to the end of the record.
John w
Dec 16, 2007 | Audio Players & Recorders
Emerson NR305TT - Replacement Turntable Needles
I have the same model. Though I haven't replaced the needle yet, I was able to remove the broken one. You'll see that the arm has a red plastic attachment. It houses the needle in a very thin strip of something like electrician's tape. There is a very small separation on the front (end of the arm facing you) of the tone arm, where the arm (black plastic) and needle "cartridge" (red plastic) come together. I used a metal nail file and pried them apart very gently. At this point the red plastic "cartridge" with the broken needle was hanging but still connected on either side. The red plastic "cartridge" is made with tiny plastic 'bumps' that pop into indentations built into the black plastic of the arm. Again, using my metal nail file, I simply held the arm and pried the red plastic "cartridge" away from one side. It popped off the other immediately and fell away from the arm. Voila!
Hope this helps!
May 29, 2007 | Emerson NR305TT CD Shelf System
Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
May 20, 2007 | Emerson NR303TT CD Shelf System
Turntable problems
buy a better record player
Sep 27, 2006 | Emerson NR303TT CD Shelf System
Emerson NR303TT CD Shelf System Logo
427 people viewed this question
Top Emerson Audio Players & Recorders Experts
Blake
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
