Question about HTC Touch P3450 Smartphone
Touch panel is not working
Trouble in touch panel
    President:
  • 1,223 Answers
Needs to be replaced , if it does not respong to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now all data will be lost in factory reset process and if u touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Posted on Mar 07, 2009
  • Shoaib Rais
    Shoaib Rais May 28, 2009
    100% correct solution get it checked
    KINDLY ENCOURAGE US TO HELP OTHERS !
    I was trying to help and it is Free as u know i am not getting any
    financial gain from helping u, the only thing i need is good rating, so
    kindly update ur rating for the solution and more questions are welcome
    Regards
    Zohail
  • Mohammad Akhtar Dogar
    Mohammad Akhtar Dogar Feb 21, 2014
    still i have problem
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
Konica minolta bizhub 350 touch screen not working
Remove the plastic cover located in the right side of machine near USB and LAN port,touch the reset micro switch,on the screen panel is displayed Touch panel adjustment and adjust the panel,press the Trouble reset and the Exit to return in copy mode.If necessary repeat the adjust.
Jul 21, 2013 | Office Equipment & Supplies
The dryer isn't drying. The top an the control panel are very hot to the touch.
Hello Rodney.
What the most probable trouble with the dryer making it very hot to the touch while at the same time not drying is a poor air flow problem. That could a be a broken blower wheel,a blocked or restricted vent.
GENE
Nov 12, 2011 | Dryers
Machine trouble c0501
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day good luck
Dec 31, 2010 | Minolta DiALTA Di350 Laser Printer
How can I reset the auto touch panel on my Sharp microwave R-7260
I had a similar problem. I suspected dirt or something got into the touch panel (keyboard). The problem went away after several weeks. I have reason to believe it could be related to humidity. Try putting it in a room with a dehumidifier.
Apr 30, 2010 | Sharp Microwave Ovens
Help me please my minolta cf 2001 is shown the code- c13cb
Enter in service mode:press meter count key and press Stop key-0-Stop-0-0-1.Select the trouble parts if appaire on touch panel,or select rhe counter window and press the trouble parts.If appaire trouble window press and in this location appaire all trouble and error codes description and the malfunction location.
Nov 20, 2009 | Office Equipment & Supplies
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Aide
The trouble code liste to be found to acces Tech.RepMode function tree:
Press Utility key and Stop - 0 -Stop - 0 - 0 - 1,touch Meter count windows on the touch panel,select tech.rep.mode,select counter,select trouble.
Jun 17, 2008 | Minolta DiALTA Di520 Laser Printer
HTC Touch P3450 Smartphone Logo
190 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
