Question about Samsung S860 Digital Camera
Samsung S860 Camera Does Not Turn On
My digital camera, a Samsung S860, does not turn on. Replacing the batteries does not seem to work. When I press either the Power or Review button, the green light blinks but then the camera does not turn on. When I hold the power button the light blinks repeatedly (same for the Review button). I have tried holding the battery cover, switching the batteries, checking for debris in the battery case, and changing to new batteries altogether, but nothing seems to work.
Thanks for your assistance.
  • Anonymous Mar 10, 2009
    exactly the same problem. Wont turn on but the status lamp keeps flashing green,. changed batteries, cleaned it out, only had camera 2 weeks, second time using it and have this issue
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
  • 5 Answers
How I fixed my Camera:
> First take your Memory card off, and remove battery
> Now, leave your camera without battery-power
=(wait for while!)
>Then,start your camera WITHOUT Memory-Card.
Note: MiniSD Card with adapter, may crash/freeze camera.
(so use the real "one piece" SD-card, not that Micro-thing!)
>When i removed the old SD card, everything was OK.
I hope this can help many others?
GonaOne from Finland.
Posted on Mar 26, 2009
dlundmark
  • 797 Answers
SOURCE: Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Posted on Oct 20, 2009
SOURCE: Samsung S860 won't power on. light blinks green, will not start
Same problem. Tried changing batteries, but no luck. However, after reading that someone else had solved the problem by using "extra heavy duty" batteries, I got some ACDelco Super Alkaline batteries, and the camera came alive! :-)
Posted on Dec 20, 2009
SOURCE: samsung s860 digital camera turns
problems with batteries going dead before you get to use it.
Posted on Apr 13, 2011
How will i fix my samsung S860?
The only safe way is to take it in for service so there is no further damage done.
Dec 21, 2012 | Samsung S860 Digital Cameras. 8-megapixel...
How do I turn the flash off of a Samsung S860 digital camera
Press cursor-left (marked with a lightning bolt) to bring up the flash menu. Select the lightning bolt in a circle with a slash through it to turn off the flash. Full details are in the "Flash/Left button" section beginning on page 28 of this manual.
Jan 24, 2011 | Samsung S860 Digital Camera
Samsung s860 makes beep noise and then turns off wont turn on batteries are charged
well i had the same problem it means it doesnt like that type of batterie i find alkyline works best
Jul 06, 2009 | Samsung S860 Digital Camera
On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Camera won't turn on
yes,they have and i bet its all becausu your using regular batteries,you have to use energizer litium batteries.try it.good luck.im a photo technician,and sold digital cameras for 3years as a lab supervisor.and i have the same camera too,its awesome.
Apr 09, 2009 | Samsung S860 Digital Camera
S860 digital camera will not come on.
try to remove battery then put it back then try to press the battery cover while turning on the camera..
Dec 25, 2008 | Samsung S860 Digital Camera
Samsung S860 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
