Question about Dell Dimension 3000 PC Desktop
Unable to change resolution
Used Drive Scrubber can't change resolution to accomodate Click-Free Hard Drive restore due to screen size. Have all the Windows reboot discs loaded but can't get any of my saved files back in from my Click-Free external hard drive. Control Panel, Display, Settings, Advanced..........none of that allows me to move that slider toward the LOWER RESOLUTION side.
Using my laptop now.
  • 1 more comment
  • canampair Mar 06, 2009
    Yah, Hi......well, first of all it's a Dell Dimension 3000 desktop PC. I put all my files onto an external hard drive and then used a software called Disk Scrubber and wiped everything clean. So then when I went to put some files back into it from the external hard drive, called a Click-Free that's a plug and play, I can't see the whole other words, what I need to click on (RESTORE) is OFF my monitor screen. So I've tried to change the resolution by going to Control Panel, Display and Settings to access the little slider gizmo that let's you go from high resolution to low resolution because somebody told me that I needed to lower the resolution in order to see everything on the screen, but that little slider gizmo WON'T SLIDE. It's frozen there at the extreme left side of the bar. I've gone to the next page of that window (tab) that says Advanced and then click on the tab that says Monitor. I can't change, modify, verify or do anything with that because it just says DEFAULT MONITOR. So............I can't reload ANY info back into that Dell until I can SEE the whole screen in order to simply click on RESTORE.
  • canampair Mar 08, 2009
    Okay Machado Jr, I'll try that just as soon as I figure out how to get on the internet again with that computer !!!
  • machadojr_fe May 11, 2010
    What type of machine is it? It sounds like you need to install a graphics driver in that machine.
  • 916 Answers
Click this
Choose the correct options and then click on Videos and try those driver listed there one should fix your screen problem
Posted on Mar 06, 2009
System is very slow both on WIndows and Linux platforms
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 18, 2013 | Computers & Internet
Can you restore my laptop screen to full size at the moment it is half size
Open up a web page on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size % click a different percentage
also a text size you might try a different text size although this will not increase the size of the page only the text inside it
if you do not see these tabs in the top toolbar right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
right click in the top toolbar select the menu bar this will add the menu to the toolbar then select the view option then from the drop down list select full screen
Change the resolution of the screen to its maximum in cases where the screen size has been compromised due to selecting a non-native resolution.
To accomplish this, right click on the desktop and select the option to "Personalize."
From there, click on "Display Settings," then slide the resolution bar all the way to the right and press "Ok" to confirm your choice.
This should restore your screen to its proper size.
hope this helps
Sep 17, 2012 | Dell Latitude D 630 D 640 D 520...
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
My on screen display has gone small
What do you mean has gone small? You mean your icons are smaller?
Try changing your screen resolution. Right Click on an open space on the desktop and select Properties. When the Display Properties window opens select the Appearance tab. Look down at the bottom and you can make sure your Font Size is Normal, if not change it to Normal. Click the Settings tab and change your screen resolution. The higher the resolution, the smaller the icons. Size 1024x768 is what most people use.
You can also get to the display properties to perform the steps above by clicking Start/Control Panel or Start/Settings/Control Panel. Look for Display or Appearance and Personalization. Open it and the display properties window will open.
If you are using Windows 7 you can also just click Start and in the search box type Screen Resolution. Look up at the top for the search results and click on Screen Resolution.
If you can't get it back to the way it was you can try doing a System Restore. System Restore allows you to select a Restore Point (date and time) before you started having problems. So if you display went small yesterday, then select a restore point before yesterday.
System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). To start System Restore click Start/Program/Accessories/System Tools/System Restore then select a data and time before you started having the issue.
If you are using Windows 7 you can just click Start then in the search box type System Restore and look up at the returned search results and select System Restore.
System Recovery on the other hand deletes everything and sets your system back to when your first purchased it.
May 20, 2012 | HP Computers & Internet
Yes I have forgot my password on my toshiba Satellite L3550 and I cant do any thing on my laptop. I dont have a boot disk either, is there anything I can do to beable to use my computer again
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
Restore Partition C: of HDD without changing current partition size
Restoring the C: drive to its factory default state formats your drive. Your information on the drive will be overwritten, and lost. Be sure to back up all important files first. If you have created other partitions (for example, a D: drive) those partitions and any information on them will not be affected and will remain intact.
To restore only the C: drive:
  1. Press 2 to restore only the "C:" drive (the letter C is traditionally used to designate the first volume on the hard disk drive) on your computer. A confirmation message will appear, indicating that all information on the drive will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
Restore Image to C: Partition with user specified size
Resizing and restoring your C: drive to its factory default state formats all partitions on the HDD (for example, if you created a D: drive, it will be deleted during the recovery process) your information will be overwritten, and lost. Be sure to back up all important files first.
To resize and restore your C: drive:
  1. Press 3 at the Toshiba HDD Recovery Utility screen. A confirmation message will appear, indicating that all partitions will be reformatted and all information will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click "Yes" to begin the recovery and to specify the size of the C: drive.
    • Press the Left/Right Arrow keys to increase/decrease the C: drive size by 1 GB increments.
    • Press the Up/Down Arrow keys to increase/decrease the C: drive size by 5 GB increments.
      The size of the C: drive will be displayed on the progress bar as you make your selections.
  3. Click "Enter" to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
  4. Press any key to restart the computer.
Aug 12, 2011 | Toshiba Satellite L355D-S7815 Notebook
All the print on my screen is to tiny to read what do i do to get it back to normal size,car'nt even read my email
open control panel, click display, then settings tab. change to lower resolution for larger type. or you can increase font size in the display setting too.
Sep 16, 2010 | CMS (DELLD600400M54) 40 GB Hard Drive
My sister changed the font size on her laptop and applied it now she can't read anything because the font is so small. how can she change it back?
Right click anywhere on the desktop . Select "Properties" from the drop down. Then click the "Settings" tab and using the slider bar move it to the right until it says `1024x768. Thats a pretty standard setting. Click "Apply" then "OK"
Apr 04, 2010 | Acer Aspire One A150-1006 Notebook
Everything on my screen seems inflated, though I
Right click on a free space on your desktop and goto properties, the click on the tab that says settings and change the screen resolution to your liking. This should solve your problem.
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Trying to print PDF from HP Pavilion 2000 laptop notebook...the screen is too small to accomodate the dialogue boxes so that I can't change properties to grayscale. Thank you
On display Properties (setting tab) change screen resolution to get smaller characters on same screen, fix the issue, restore previous resolution
Jan 13, 2009 | Computers & Internet
E Machines
In this situation I would start by testing the hard drive then the RAM.
For the hard drive find out the manufacturers name and download their test program.
For the RAM test I have used a free program call memtest86 with very good results.
If the problem is the hard drive, you may be able to install a hard drive of the same size and using an imaging program copy the old drive to the new drive. Re-run the recovery program. My suspicions are that the old drive has developed bad clusters near the beginning where the operating system is and some of the files have become corrupt.
If the RAM fails the test replace the RAM and try again.
Apr 27, 2008 | Dell PowerEdge 2500 Server
Dell Dimension 3000 PC Desktop Logo
230 people viewed this question
Alun Cox
