Question about LG 37LC7D 37 in. LCD HDTV
AT&T remotes won't do mute function on tv's
Sir or Ma'am: I recently purchased 2 new LG flat-screen HD TV's. Then about 10 days ago, I switched my TV, phone and internet provider from Comcast to AT&T. The only problem I have is the remotes that came with AT&T will not do the mute function on either TV. The AT&T tech actually programmed the remotes when he installed the system in my house and the remotes will do everything else like volume, turn on and off, but not mute. The TV code for LG brand listed in their remote control program handout has only 1 code listed.....1005. Do you know of another code I can try? Or can I program the mute function separately on my remote?
Thank you.
Steve Turco, Orange Park, FL
    Sergeant:
    Champion:
  • 267 Answers
Contact att it's their problem
Posted on Mar 06, 2009
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
The Akai TV MA TE02 lost sound
It sounds that the audio output section circuit has the fault. Check it audio out pre-amp sockets at its back, connected to any external Amp. See whether audio comes out by this way. If not, the main digital board is faulty. If yes, audio output section is faulty.
Dec 31, 2012 | Televison & Video
My Comcast Proscan HD TV has a small screen on non HD channels.
I have 2 pro scans Comcast hd. On Comcast remote small button ( for me Its small circular button bottom right) HD ZOOM. (enter above it)
Aug 30, 2012 | Televison & Video
I might of hit the wrong button when i was trying to switch inputs... The screen asked for 4 number password but i never had set one. So i just turn the tv off and on but now my tv shows vizio on the...
Dear Sir:
Follow this step:
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
  • 2 Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
  • God bless you
    May 14, 2012 | Televison & Video
    I am using the AT8560 remote and my mute function does not work. Can you help me?
    Ur tv mute button might not be function anymore,because of rubber inner layer are worn out or the main CPU chip of the remote itself it shorted causes this problems.U have a Digital Camera,turn it on.Put the tv remote wright in front of the camera press the remote mute button,u will see on the camera viewing screen the mute button work or not wright away because Digital camera can read infer red signal output.Try website like Remotes.com to buy a new original remote or a very closed compatible one.
    Jun 13, 2011 | LG 42LC2D 42 in. LCD HDTV
    Hi, I've purchased a 2nd hand LG 42" Plasma TV set
    Usually black lines in a flat panel indicate an error or problem in the video board. A service professional can hook up to the tv and better diagnose the issue.
    Mar 23, 2011 | LG Televison & Video
    LG 50PJ350 TV - if watching DVD and on pause for more than 10 minutes, the TV switches off. Why? Can I stop it switching off?
    Its going into standby mode and unless you hit a button on the remote or the TV, the TV assumes you are not watching and turns it off as a power saving feature. You used to be able to disable this feature by holding down menu on your remote and holding down menu on the TV for about 10 seconds however with this model TV that option is not available with the remote provided. I'm told you need to purchase a 105-102M Service Remote and that will allow you to get to the service menu to disable the Standby feature. Good Luck!
    Feb 11, 2011 | LG 50PJ350 50 in HD-Ready TV
    I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
    This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
    NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
    Thanking you
    Aug 04, 2010 | LG Televison & Video
    LG 37LC7D 37 in. LCD HDTV Logo
    355 people viewed this question
    Computer Repairing
    Computer Repairing
