Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Error code er dh
I have changed the PCB main and also the ice making motor in the freezer and I am still getting the ER DH code. The refrigerator works and makes ice but the code continues to appear. Is there a reset button I have have set after changing out the PCB main. I did the motor first then the board when I continued to get the error code. Thanks
    Master:
  • LG Master
  • 304 Answers
Hi!
Please check the "Troubleshooting" part of the manual to a similar LG fridge
https://manualsbrain.com/en/manuals/942858/?page=37
Posted on Oct 24, 2017
SOURCE:
  • 60 Answers
SOURCE: LG Refrigerator
That stands for a defrost heater problem. Usually it's the defrost detect circuit that has a blown thermal fuse.
Posted on Dec 20, 2007
  • 27 Answers
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Posted on Jan 06, 2008
  • 1122 Answers
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Posted on Jul 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 24, 2010
  • 489 Answers
SOURCE: error message on the display panel that says ER dH
ER dh means you have defrost issue that needs to be addressed asap. The evaporator has frosted up so badly that the circulating cold air cannot get to the refrigerator. You would need to get inside the freezer back panel and remove it to access into the evaporator coil area. Test the defrost circuits to see if the defrost terminator is broken. If it is, replace it and melt the ice build up as well.
Good luck
Posted on Jul 16, 2011
Kenmore bottom freezer refrigerator showing ER on one side and DH on other on temperature control
Hello Mike,
It means that most likely that your Defrost Heater (DH) is not working and one of the following items could be bad;
Er dH Sensor did not get over 40 F Faulty fuse, heater, control board Controller assembly, defrost heater, relay on control board Here is the whole list for your refrigerator;
Kenmore Bottom Freezer Refrigerator Error Codes for 795 Models Sears...
Good Luck!
Rich Lilja
May 12, 2018 | Kenmore Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
What is wrong when I receive error code Er rF
Hello Anonymous!
Error code Er rF is an :Abnormality of BLDC FAN Motor for Freezer.
  • The freezer fan motor may be Defective.
  • Unplug the fridge for about 30 minutes and plug it back in, if the code appear again within 24 Hr , the Main Board might be defective too.
  • Check if the freezer fan is blowing normally, then the Main board has a problem.
  • If not, the Fan Motor is defective or both.
  • I would change the Fan first then the Main PCB
Good Luck,
JP
Jul 09, 2015 | LG Stainless Steel French Door...
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite error message er ff
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I ahve a Kenmore Elite side by side refrigerator with watre and ice on the front and freezer below..there is a message Er IF on the dispaly and it will not make ice..this unit is 1 1/2 yrs old..the freezer...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Dec 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer Refrigerator Model #795.77562600 Serial #608KR00238 The control pad is locked up, it dispalys Er CO. You can't change from water, ice to crushed ice. The ice maker runs. It...
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 13, 2008 | Refrigerators
Er dh ken bot.fridge. 795.77552600
one thing to try first is make sure there is enough air flow in the freezer and that the airway between the freezer and refrigerator's is free and clear
Mar 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
195 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
