Question about Dual XDVD8181 Car Video Player
Red blinking light around power button of xdvd710
I have the xdvd710 and the other day I was listening to it driving then when I got back into my car the power button had a red flashing ring around it and it was beeping. Know, thats all it does I cant reset it, I cant turn it on and it wont take in dvds. Does anyone know how to fix this problem?
  • SteveoAudiA4 Mar 31, 2009
    Red light is flashing around my volume button I called Dual and they said that it is more likely the power supply.
  • Anonymous Apr 29, 2009
    ************ keeps blinking and beeping and i cant find the solution the red light is off and on it wont let me do nothing
Does anyone know how to fix this problem? I am having the same problem. P.O.S. Red blinking light and annoying beeping...
Posted on Oct 22, 2009
  • 36 Answers
The problem is the power supply, my cousin had a second dual radio that the screen did not work so I took the power supply out of the old one and put it into the other Dual radio and it worked. so his is fixed. you will have to change the power supply.
  • SteveoAudiA4 Nov 03, 2009
    it is the complete board at the bottom of the unit, where the connecter plug plugs into that whole board goodstuff7
What/where is the power supply?
Posted on Nov 02, 2009
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Just hooked up dual xdvd710 but all it does is the button blinks red and beeps. What is wrong?
it sounds like a wiring problem i have seen these in many in dash dvd players. if you still have the manual just check your connections and your grounds there may be a short or mis matched wire
May 14, 2011 | Dual XDVD8181 Car Video Player
Simply blink red light in front or power led light ,no display anything .power on button is on blink red
Try to do a Hard Reset. Disconnect all peripherals connected from the unit (power adapter, monitor, keyboard, etc) then press and hold the power button for around 15 seconds. Plug everything back then power the PC on.
Hope this help. Goodluck!
Mar 28, 2011 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
No picture, just a red blinking light
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Feb 07, 2010 | RCA Televison & Video
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I can't get my tv to turn on... nothing but blinking red light
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Aug 17, 2008 | Philips 26MF231D 26 in. LCD Television
Where can I find a Samsung repair center?
LG DLP PROJECTION TV (RU-44SZ63D) Tv light is off (with red light on). When I hit the power on button the red tv light starts blinking. Light continues to blink red then stops blinking and goes back to off (red light on).
Jul 12, 2008 | Televison & Video
Does red light around the power button stay on at all times when the car is off?
the light turns blue because there is a disk in the unit.. if you take it out it should turn red (at least on my Valor unit)
Apr 18, 2008 | Dual XDVD8181 Car Video Player
Dual xdvd710
Put in the same number 3 times (example 1111) until it locks and then push in the mute bottom and hold it and while you hold the mute button with your other finger push in the volume control (power button) and hold both of them until a new screen comes up and then put in 122164 and hit OK and that should work.
Mar 24, 2008 | Dual Electronics XDVD710 Car DVD Player
Dual XDVD8181 Car Video Player Logo
1,429 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Neville Ward
Level 1 Expert
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
