Question about Akai LCT2662 Television
Im looking for a wall mount for my LCT2662-n tv and what is the price. is it suppose to come with the tv upon purchase.
  • 139 Answers
No.
Find a mount - search for Chief Mounts online. They will have one.
Posted on Mar 06, 2009
Generations 9316G TV Mount Won't Tilt
The installers did not anticipate you would be wanting to tilt the TV upward so did the usual.
Apr 14, 2017 | Televison & Video
Hi, we have just bought a second hand Hitachi Hi Plasma TV Model PD1, 42PMA400A. We have a wall bracket but what we'd eally like is a stand ... the base plate and two stems that go into the bottom of...
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there from someone who has their TV mounted to the wall and is no longer using it. These are normally fairly heavy and bulky items, so Ebay purchase prices and shipping costs can vary widely.
I did not see any for your exact model of TV available there when I looked, but the online selection changes daily, so you can always keep checking back. Just search on Ebay for 'HITACHI TV STAND' or 'HITACHI TV BASE' and you will see a wide variety of them available for different Hitachi TV models as well as what the average price for them is.
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
http://cgi.ebay.com/PLASMA-LCD-FLAT-PANEL-MOUNT-TV-STAND-WALL-SHELF-STAND-/390330001764?pt=LH_DefaultDomain_0&hash=item5ae17b2964
http://cgi.ebay.com/Plasma-LCD-Flat-Panel-Console-Shelf-Wall-Mount-TV-Stand-/270797719452?pt=LH_DefaultDomain_0&hash=item3f0ccd479c
I hope that was helpful to you, good luck and take care.
Joe.
Aug 30, 2011 | Hitachi Televison & Video
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
I have a PLTV-32CM flat screen TV that I purchased new in 2006. I want to mount it on the wall now and I have a wall mount that I purchased at the same time but never used. When I went to put it on, it...
Yes, it can be mounted on the wall mount bracket system. You may not have bought the universal adjustable mounting bracket type to match the VESA mounting dimension (the four monting holes spacing measured in mm).
See example here:
http://www.affordablehdtv.com/advanced_search_result.php?osCsid=3q5p8vevt3jbjuj19qc2mu4rr1&keywords=pltv-32&x=25&y=9
Please leave rating if it helps.
Jan 20, 2011 | Protron PLTV-32 Television
Is there a wall mount kit I can purchase for my Proview 3200 326
There are pretty much wall mounts for every flat screen tv out there. Target sells them. You just purchase by using the size of your tv and there should be brackets that match the screw slots on the back of your tv.
Nov 28, 2010 | Proview PA-32JK1A 32 in. LCD Television
Need stand or wall mount braket
Wall mount brackets are a great solution as they remove clutter from a room and depending on the model you can move it in an array of positions. You can find a good mount bracket for a good price on ebay, just search tv mount. Just ensure before purchase that the VESA number is compatible with your TV or if they give you details on the screw locations required on the TV then use that.
Hope that helps
Oct 08, 2009 | Balance CM2017 17" Monitor
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
AKAI LCT2662 Schematic
I was looking for the same thing- I found this, which I am 99% sure is the same TV under a different name - even the remote is identical.
MODELO: BSV-2652
May 24, 2008 | Akai LCT2662 Television
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Akai LCT2662 Television Logo
51 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
