Question about Canon LaserClass 2060P Plain Paper Fax
I just changed the cartridge in the canon laser class 1060P and now all the faxes are coming out black. It looks like I took the toner and spread it out on the page. The manual does not help me fix this problem.
  • dannette_fou Mar 09, 2009
    Thank you for your help copiersplus. I had actually already put in another new cartridge before I started asking for a solution. I have now sent it in for service since I dont think it is a cartridge problem. We are not in CT but AR.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Wellll, DUH
    Scholar:
  • 136 Answers
Ok just cause you put in a NEW CARTRIDGE DOESN'T mean it was a good one, if your getting black pages this tells me that tour toner is getting no charge, this tells me that your charge roller isn't charging, either your cartidge is no good, yup= this could be defective or your charging unit on your printer become defective- replace ctg first, if it doesn't correct it then CALL FOR SERVICE, r u in Ct if so we can help you !!!!!
Posted on Mar 08, 2009
When the fax machine says "close the cover/cart" how do we clear that error message when we have checked over the fax machine, closed everything, and checked for jams.
Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
May 05, 2011 | Canon LASER CLASS 2050P
Our canon laser fax 1060p receives faxes fine but send out a total black page (also the copy function is a total black page)
No power/failed contact image sensor. If under contract get replaced. It is poss. that a "standard white setting adj." could fix it, but doubtful with a black copy. -Carl
Jul 17, 2009 | Canon L220 Plain Paper Laser Fax
Canon PC1080f copies coming out blank
Did you pull the plastic tape off of the cartridge?
Feb 09, 2009 | Canon PC-1080F Plain Paper Laser Fax
Canon L75 Black Vertical Line
the problem is with the cartridge itself and should be cleaned as the toner has dropped on to the roller inside the cartridge and causing the lines. or you could change the cartridge and see if that works.
Jun 06, 2008 | Canon FaxPhone L75 Plain Paper Laser
Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
May 19, 2008 | Canon FAX L-120 Plain Paper Laser
PAPER FEED
the drum of toner crtridge has expired chande the drum if available,otherwise change complete toner cartridge
Sep 17, 2007 | Canon FAXPHONE L80 Laser
Canon LaserClass 2060P Plain Paper Fax Logo
99 people viewed this question
old marine
old marine
