Question about GPS
My GPS windsheel holder is not holding my
My GPS windshield holder is not holding my GPS for more then 2-to 3 minute the fell down, can you replace this holder for me I have for approximately 7 month
Thank you
  • dirinda89
    dirinda89 May 11, 2010
    You need to contact the manufacturer of your GPS device.
  • 74 Answers
Moisten the ****** with a little water then it should stay on the window for longer. Make sure the window is clean and the ****** is not damaged.
Peter
Posted on Mar 07, 2009
Nexus 4 LG plugged my phone as batteries where dead. Won't come back on. It shows battery charging and has been charging for 2 to 3 hours.
Press and hold Volume Down, and then press and hold Power simultaneously until the device turns on.
Hope that helps!
Nov 01, 2013 | iOttie One-Touch Bike Mount Holder for...
Rear view mirror
1. Slide the metal disc off the base of the rear view mirror assemble. For newer models of cars the metal plate may have to be removed with a properly sized Allen wrench. These are L shaped wrenches that are designed to remove hex head screws and can be purchased at any hardware store. While there you should also pick up a razor blade scraper and some masking tape.
2. Head to your local Schuck's or other automotive store and purchase a rear view mirror adhesive kit for around $3. This super strong adhesive is a two part system that comes with a tube of glue and a vial of accelerant.
3. From the outside of the car, use masking tape to mark the area where the old glue adhesive still remains.
4. From the inside, scrape off whatever is left of the glue residual.
5. Since this glue only works in temperatures of 60 or above, you will have to make special provisions when the weather is cold. The car should be placed in a warmed garage or facing the sunlight. A blow dryer can also be used to heat up the windshield, although don't hold it too close to avoid cracking the glass.
6. Once the glue has been scraped off the windshield, wipe down the area with rubbing alcohol. The metal plate should also be wiped down with alcohol.
7. Apply the accelerant directly to the mounting area on the windshield. Allow to let dry 5 minutes. In the meantime, apply the accelerant to the flat part of the base plate as well and let dry.
8. Slather on the adhesive on the back of base plate and press it onto the glass. Hold in place for about 2 minutes until the glue begins to set up. Let the glue dry overnight before reattaching the rear view mirror.
Jun 11, 2013 | Cars & Trucks
I have a 2003 Jeep liberty. the windsheel washer does not work in tront or rear. I check the fuse and it is not blown.What should i cleck now.
Pull the plug from the windshield washer pump and check the contacts. The contacts may need cleaning with 90% rubbing alcohol and Qtips. Check for voltage at the contacts.
Mar 22, 2011 | 2003 Jeep Liberty
Have tom tom go 910 and can't separate unit from windshield suction cup holder
holding the gps and mount in your hands, looking at it sideways, push the release on the mount (at the cradle) and tip the bottom of the gps toward the top.
is kind of tips into place, if you know what i mean. it can be a real pain sometimes getting them separated.
Bill
Standing Member of G.O.T.
Please Support Our Troops
Mar 12, 2011 | Tomtom GO 910 GPS Receiver
I lost the GPS dock which is sticked on the windshield. where can i possibly buy a new one?
Do you mean the sucktion cup windshield holder? If so you can either get one on Ebay or go to www.MyGarmin.com and look under accessories.
I prefer MyGarmin at least you know you have the right holder for your product.
Oct 19, 2010 | GPS
Need replacement windshield holder
Go back to the store where you bought the unit and see if they have the part you need, if not head to wal mart and see if they have a universal install kit. If the manufacture used standard mounting points then you should be ok with one of the universal units. If not then you might have to go back to the factory to get it. ie call sony and see how much it is for a new mount.
Mar 12, 2010 | Sony NV-U73T GPS Receiver
Plastic pholder for my Garmin 255W will not stick to windshield
The glass and attachment suction cup should be clean and free of oils, dust hair etc. Try cleaning both surfaces. If this doesn't workyou can order a new holder from Garmin.
Aug 02, 2009 | Garmin Nuvi 255 GPS Receiver
How replace mirror on windscreen?
This happens a lot. There are several brands of adhesives sold at autoparts stores just for rearview mirrors. You should see an outline of the glue on the inside. Take some tape on the outside and mark where the glue is. Then use a razorblade and the solvent in the repair kit and clean the inside. The mirror comes out of the holder with an allen wrench. Follow the instructions in the kit and press the mount to the windshield. Hold it there at least 3 minutes. Wait for it to dry per instructions. Then add the mirror and lightly tighten the mirror to the base. I like the kits which have 2 parts of glue. On my car I let the excess glue stay on the window.
Jul 01, 2009 | 2001 Ford Windstar
Rearview mirror fell off windshield! Not broken...
the mirror should simply slide over the metal mount (button) that is glued to the window.
loosen the set screw on the mirror mount...
hold the rear view mirror mount on the glass just above the metal mount (wide end of plastic opening facing down)
slide it into place...
secure it by tightening down set screw you loosened earlier.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 22, 2009 | 1998 GMC Jimmy
Sony play station 2 disk holder wont open
I think, either the "hook" that holds the cap of the holder has been stuck or broken and jammed...have you tried opening it? I recommend having a "fixer" do the job and check it for you...
Jul 24, 2008 | Sony PlayStation 2 (PS2) Console
GPS Logo
42 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
