When I turn on the Wii console, the cursor does not appear on the home screen, I have tried both controller's and nothing, this started mid-game.
Step 1:
First we should try to identify whether it is the sensor bar, The Wii, or the remote itself. So, let's start off by trying out the sensor bar. I would recommend you putting two (decent) sized LIT candles on both sides of the sensor, or try simply cleaning off the sensor. If the candle trick works, you have a bad sensor and need to buy a new one. If nothing changes and you're still in the same boat, then we'll try to see if it's the remote.Step 2:
For the remote there's not too many things that can go wrong it, but we'll see if it's the remote. What you wanna do is see if the if the Wii remote has a dirty top to it (black thing on top). This will cause the IR camera to not be able to locate the sensor. If this fixes it then you'll save some money, but if it doesn't we'll try something else. Now, what we got might be a bad IR camera in which you have to buy a new controller (I suggest trying some neighbors remote or a friends to make sure this is the problem). Another thing that might be a problem is any secondary IR light source will cause interruption with the communication from the sensor to the Wii remote, but I highly doubt this is your problem. Step 3:
Now, if all of these fail it is more than likely something with your Wii console and I would highly recommend you contact Nintendo Customer Service http://www.nintendo.com/corp/contact.jsp for they might have more knowledge than me about that. I hope that this helps you out!
SOURCE: the wii menu does not appear on the tv screen but
First check your cable connection.
Eject the disk, if you have inside.
Unplug the console at the back
Wait 10 minutes
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
If this not help may your Wii need service.
SOURCE: Black and white screen for new wii console
It's most likely because the US Wii is NTSC and your European TV is PAL.
SOURCE: Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
SOURCE: Wii will not load past Health and Safety screen.
Try a hard-reset. Unplug the console from the Mains For 5-10 Minutes.
Wii returns back to default settings.
Thankyou for Using Fixya.
Mike @ Compurepair.
SOURCE: wii console not turning on
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
185
