Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No Picture with sound
Sharp AQUOS LC32GA8E the tv is connected with a sky box, dvd and vcr, when the tv is turned on the picture will display for a few seconds then go off, after tkaing the scart connection out and putting back in a number of times the picture will come on, however this is taking longer and longer each time.
  • kreutzer99 Apr 09, 2009
    I have the same problem. How do I fix it? replace the backlight lamp?
  • Anonymous Apr 22, 2009
    tv has a good peacture and in 1 minute the lamp go off put it on and same problem
    Sergeant:
    Champion:
  • 267 Answers
Sounds like you have a bad panel. This ussually happens when a backlight lamp has gone bad and the inverter board senses this and sends a signal to turn the backlight off.
Posted on Mar 06, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
New toshiba tv connect to sky plus box and perfect picture but no sound
The first thing to do is check the connections between the Sky box and the TV. If you are using a SCART cable, it's possible that one of the pins in the SCART plugs has bent or become detached from the wire inside. If you have another SCART cable from a VCR or DVD player, try switching them over.
If this doesn't work, or if you are using another connection method between the Sky box and the TV, please post back and I will try to assist you further.
Regards,
BElectric
Nov 29, 2010 | Toshiba Televison & Video
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
Lcd tv no picture but does have sound
its the problem of the socket where you insert the wire in the tv that is gone loose internally and has to be resoldered.if done it again n again the socket will get completely bent or crack internally .so get it repaired donot remove and reinsert wires again n again it will damage the socket.
Mar 06, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos TV will not display contents of DVD using Microsoft Media Player 11
it sounds like a problem within your vga connection on the tv check around and see if there is some firmware for this fix or right click on your desktop were there is no icons and select properties select settings tab and set ur display as needed.
C
Oct 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Oct 06, 2007 | Televison & Video
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
493 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
