Question about Canon PIXMA iX4000 InkJet Photo Printer
Error message tells me the top is open it isn't,
Error message tells me the top is open & it isn't, and the ink holder stays in the middle
  • jt1332003 Mar 06, 2009
    I've checked that. It doesn't look broken and presses down ok. wondered if there was something inside that was not working
    Sergeant:
  • 300 Answers
When the top is opened there is a sensor which comes up and the cartridges come in the center.when the top is closed the sensor gets pressed due to the closed topo and the cartridges move towards in.as the cartridges are coming in between and you say top is closed this indicates that the top lift door sensor is out of position or it is not getting pressed just check out properly the sensor is getting blocked or its broken.
Posted on Mar 06, 2009
How to repare a inkjet photo printer ip 8500 whith error message 5200 thank you
Solution from another FixYa topic:
(1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
Jun 04, 2011 | Canon PIXMA iP8500 InkJet Photo Printer
Hi I am getting a 5200 error message and install the correct printer head. Funny I have not touched the printer head.Any thoughts.
Hello and Welcome to FixYa!
Error 5200 is a
service error. Follow the given steps to solve this error:-
  1. With the printer turned on,unplug it
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
Any more confusion, queries or for further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
May 08, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Pls let mr know Error number 5200 for printer Canon Ip 2700
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
bhupi
May 03, 2011 | Canon Office Equipment & Supplies
My problem is I can't my any file print. the message coming error no 5200. How can i solved?
Mar 05, 2011 | Canon Office Equipment & Supplies
Error 5200
This error indicates that the Waste Ink tank is full. In some cases, resetting the counter will fix clear the error, but in some cases, it couldn't be fixed until you clear or clean the ink pads inside the waste ink tanks.
First try this:
  1. With the printer turned on, unplug it.
  2. Open the top and bring the ink cartridge holder to the middle.
  3. Raise the gray bar and remove the print head assembly with the cartridges in it.
  4. Lower the gray bar with the head missing and close the top with the head out.
  5. Restore the power,wait till The printer wakes up.
  6. It will tell you to install the cartridges, do so.
  7. Restore the print head, close the top and the printer should resume working.
If the above trick didn't help, watch this video and follow the instructions [the model is different, but the method is more or similar, you'll only need to know how to dismantle the machine]:
You can also follow this "How to" [Click Here].
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jan 31, 2011 | Canon MP490 InkJet Printer
5200 ERROR SHOWS UP AND WON T LET ME PRINT. WHAT DO I DO?
3. Raise the grey bar and remove the print head assembly with the cartridges in it
4. Lower the grey bar with the head missing and close the top with the head out
5. Connect the power, wait till the printer wakes up
7. Restore the print head, close the top and the printer should start working
Sep 20, 2010 | Canon PIXMA MX330 Multifunction InkJet...
5200 error
Jul 08, 2009 | Canon Office Equipment & Supplies
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Help with Epson Stylus CX 6000
Hi Open the cover then switch on the printer and then off from the mains when the cartridges are in the middle. Hope this helps!
May 23, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Canon PIXMA iX4000 InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
