Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi tv will not stay on
When you turn tv on it go off instant it act like the little coil is bad
  • 42 Answers
That model has a blink code to help diagnosis. When the TV goes off press The Input And Menu Buttons On The Front Panel Simultaneously And Hold Them In For 5 Seconds After 5 Seconds The Power Led On The Front Panel Will Blink A Two Digit Sequence. It will help determine the circuit but troubleshooting will be needed to check for a defective component.
Posted on Mar 06, 2009
Why doesn't TV stay powered on?
Have you tried to download the instruction manual from the Internet?
Feb 04, 2015 | Mitsubishi WS-65411 65" Rear Projection...
Why won't TV won't stay powered on?
probably not worth it. How many times does the LED flash? That will indicate your failure cause. Problem is this is an old tv and parts are not available or cost effective. Unless its bad capacitors or bad solder you could be looking at rediculous amounts to fix it. Mitsubishi WS 65413 Manuals Support and Troubleshooting TVs
here is a link to the manual. please provide the amount of LED blinks. itll blink a few times and pause.
Feb 04, 2015 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
The tv acts like it is going to turn on, then shuts off.
sounds like you have a bad flyback if the tv acts like it wants to come on and wont, i would suggest calling a shop and have them come out and have a look at it to see if they can fix it
Dec 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Tv turns off by itself sometimes
have a tech repair your tv.good luck let him look at the power supply or the related cirucits.good luck
May 14, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
