Question about Garmin Forerunner 50
This is a problem concerning Forerunner 50 Garmin. No more sound alarms works, since I've changed the battery a few weeks ago : - woken up alarm ; - interval alarms (INTTMR) T1 and T2 - interval alarms set on auto laps Chime Mode is not efficient, set on ON and on OFF. What can I do ? Thanx ...
  • 2,334 Answers
1) You have lost the connector spring wich transmits the sound signal to the tweeter positioned inside back cover. In this case you have to look for watchmakers help.
2) You may misplaced the gasket in watch and the spring is not touching the caseback through the protrusion. In this case open the caseback, realign the gasket properly and reassemble the watch. Make sur thet the spring is touching the caseback inside watch.
Do not forget to rate, please.
Posted on Mar 07, 2009
Garmin watch battery replacement
The Forerunner 50 uses a coin cell battery (CR2032).
Any watch repair shop can change the battery.
Also, contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 26, 2012 | Garmin Forerunner 50
My watch to my garmin forerunner 50 started bleeping last week and then it went blank (the watch), changed the battery twice but still not working. can you help?
I have read the instructions for your watch and I found nothing in there that was helpful.
I am having a guess here but perhaps the memory is full (did you see the "Lo mem" warning?
Try downloading the memory to your computer if you can with a blank screen!
As a last resort, go to theri web site and find the "contact us " phone number and ask the maker.
Mar 15, 2010 | Garmin Forerunner 50
Forerunner 50 resets automatically
I have the same situation with my Garmin. Have you sort this out??
Thanks.
Oct 09, 2009 | Garmin Forerunner 50
Battery Life: I have had my Garmin Forerunner 50 for only 3 months and the 2nd battery is already dead. Normal?
There is a fault with Forerunner 50's - I replaced my battery three weeks ago, after three months of average use. It posted the "LoBatt" sign again the following day. Garmin offered to replace it with an overhauled product but I've gone for a refund instead.
Jul 08, 2009 | Garmin Forerunner 50
Can't pair garmin forerunner 50 with hrm and food pod
First you have to assume the battery that comes with your HRM would be new - keep in mind that it may be stored in the warehouse for many moons.
Given that, open and take out the battery - that should make a hard reset on the HRM itself. Restore the battery and try the manual pairing again.
The heart icon should pop up again.
Otherwise, you have to suspect the battery is low and need to be replaced.
Good luck
Jun 05, 2009 | Garmin Forerunner 50
Can`t pair Garmin Forerunner 50 with footpod
I've been having the same problem. I couldn't pair my footpod, but my heart rate monitor was working. I've only had the 50 for about eight weeks.
I reset the watch, holding view mode and Start/Stop at the same time.
This didn't do any good.
I swapped the battery in the HRM with that in the foot pod. The foot pod synched the HRM didn't.
Solution duff battery. I'd change yours it will probably do the trick.
Hope it helps
John-Paul ( AKA OldGreyWizard)
Jan 10, 2009 | Garmin Forerunner 50
Garmin 50 forerunner failure
It sounds to me as you are having the problem with faulty contacts. They should be cleaned and checked for stiffness- if too weak must be replaced.
The next possible cause can be integrated circuit (IC) failure. In this case only skilled watchmaker can help you and that gonna be costly.
Dec 16, 2008 | Garmin Watches
Garmin Forerunner 50 Logo
289 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
