Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Lcd tv no picture but does have sound
The tv is connected with a sky box, dvd and vcr, when the tv is turned on the picture will display for a few seconds then go off, after tkaing the scart connection out and putting back in a number of times the picture will come on, however this is taking longer and longer each time.
  • 300 Answers
Its the problem of the socket where you insert the wire in the tv that is gone loose internally and has to be resoldered.if done it again n again the socket will get completely bent or crack internally .so get it repaired donot remove and reinsert wires again n again it will damage the socket.
Posted on Mar 06, 2009
2 Suggested Answers
  • 267 Answers
SOURCE: no Picture with sound
sounds like you have a bad panel. This ussually happens when a backlight lamp has gone bad and the inverter board senses this and sends a signal to turn the backlight off.
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
How can i tune all my sky channels to my dvd/vcr combo box
Hi sounds like the remote may be in the wrong mode , you can scan channels into the sky box or the TV/combo.
Make sure you are scanning them into the box not the combo.
Jun 14, 2012 | Daewoo Televison & Video
New toshiba tv connect to sky plus box and perfect picture but no sound
The first thing to do is check the connections between the Sky box and the TV. If you are using a SCART cable, it's possible that one of the pins in the SCART plugs has bent or become detached from the wire inside. If you have another SCART cable from a VCR or DVD player, try switching them over.
If this doesn't work, or if you are using another connection method between the Sky box and the TV, please post back and I will try to assist you further.
Nov 29, 2010 | Toshiba Televison & Video
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
No Picture with sound
Mar 06, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Oct 06, 2007 | Televison & Video
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
123 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
