Question about Sony STR-DA5200ES Receiver
No center speaker sound on my Sony STR-DA5200ES receiver
I get no sound on the center speaker. The speaker and wires work (I plug them into another output, I get sound). When I go to setup, it shows all of the speakers that are connected except the center one. Is my system broken (can it be fixed), or do I have it configured incorrectly (how do I fix that)?
  • 336 Answers
It sounds like a set-up problem. If the receiver was in front of me I could figure it out.
http://esupport.sony.com/perl/select-system.pl
goto this web site to download the owners manual it's free.
Posted on Mar 06, 2009
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
I have to connect the RCA PLUG on a Center Speaker by Audio Research to the Center Speaker connections on my Sony Receiver, which requires two wires. What do I use... a RCA plug with ...? Thanks ...
A possible solution (but not the best) is to use a single RCA to RCA cable, however you should cut one end of the cable before the remaining RCA plug. Then you separe the wires, twist each of them and hook on your Sony receiver. A RCA cable is made of two wires or poles. I believe this will work. Good Luck.
Flavio/BRAZIL
Jun 08, 2010 | Sony STR-DE898 Receiver
I have a Sony STR-DA5200ES amplifier hooked into a sound system and a 52" Samsung LCD TV. The system is set up to operate on HDMI. The problem that has started recently is that the amplifier polls between...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings.
or
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The HDMI on the Sony STR-DA5200ES does not pass the audio. You need to either connect an optical or digital cable from your audio source. If it is a cable box or DVD player there should be audio outputs in addition to HDM.
Hope this will help...
May 25, 2010 | Sony STR-DA5200ES Receiver
Own a SONY 7.1 STR DH800 receiver, how do I fix protector message?
There could be a number of issues wrong with this unit. If you have removed all inputs and speaker outputs and the unit still goes into protect you could either have a problem with the switching power supply or a shorted output stage. Both would require a trained technician to troubleshoot and repair.
Feb 11, 2010 | Sony STR-DA5200ES Receiver
What could I use to connect my speakers to the back panel of the STR DH700. My home was prewired with speaker wires for surround sound. I used banana plugs for the other speaker wires but finding hard to...
Had a set of bose AM-10 that I had to take back cuz Sony said that their receivers needed a powered sub woofer. got AM-15's and hooked them up-AMAZING SOUND.
Dec 08, 2009 | Sony STR-DH700 A/V Receiver
No Center Channel on STR-DA5200ES
Da 5200es. Workiig only two Chanel i need five chanel. ihave no remot
Aug 04, 2009 | Sony STR-DA5200ES Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Sony STR-DA5200ES Receiver Logo
249 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
