Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I have a whirlpool ultimate care washer can fill water but hums
I took it apart capacitor was fried busted wide open so i replaced the capacitor, took the motor out laid it on the floor and took the lid switch off so i can test the system before i put back together. still hums so i replced the motor and it still hums trans mission is free no hangups there can anyone help why the motor just hums in the spin cycle and only starts to move slowly when i spin the motor shaft
  • Phil Brantley
    Phil Brantley May 11, 2010
    Have you tried it with the water pump off the front motor shaft?
  • 283 Answers
Bad timer
Posted on Mar 06, 2009
I have a whirlpool ultimate care II washer. It stopped in the middle of a load, full of water, and now it won't do anything. It won't drain, fill, move, or make any noises.
You will need to check the capacitor on the machine. It can be tested with a capacitance meter the easiest. It can be tested with a resistance meter, but this will tell you if the capacitor is shorted or open. It will not tell you the capacitive value if the component has drifted out of tolerance. You put the meter across the terminals and watch the display for counting up to infinity. This will occur quickly and disappear very quickly. Now reverse the leads on the terminals, (reverse the polarity). The same thing should happen, but a bit more pronounced. It will once again rise very quickly and go to an infinite reading. This tells you that the capacitor isn't shorted or open internally. Here is the capacitor to order if you should find it bad.
Nov 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gold ultimate careII: water will fill up but will not start agitating
Can you hear the motor humming? If not then I would check the capacitor. Will it pump out the water?
If it does pump out that can only be the coupler is busted. Manual and more HERE
Oct 09, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont fill with water
Here is a tip that I wrote about no water coming into the washing machine2_bing.gif...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer hums
Under the tub is a round coupling that wears out. This needs to be replaced. When the washer is over loaded it puts to much stress on this coupling and wears it out. You have to take out the drum to replace it. As for it not filling, check the water vavles that supply the washer they may have been turned off
Sep 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Will not run or drain
My wash machine doesn't open from the front but I am having problems with it not draining
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
301 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
