Question about RIM BlackBerry ® 8830 Cellular Phone
Blackberry 8830 - World - Problem Pairing with Bluetooth
I am trying to pair my blackberry 8830 - World Edition with the bluetooth device in my car. When I search for the device on the Blackberry, it finds it without any trouble. Once I click to connect, it pauses for a second, briefly (1 second) shows the security code screen, then says it cannot connect and asks me if I want to try again. It doesn't give me a chance to enter the security code. I was able to do this without any trouble with my previous Blackberry 8830 - World Edition and can connect using other phones without a problem. Any suggestions?
  • Maddor
    Maddor May 11, 2010
    What type of stereo?
I am having the exact same problem and cannot seem to resolve it; have you had any luck over the past month?
Posted on Apr 17, 2009
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I'm trying to set up my new blackberry 8830 to work with motorola and jawbone bluetooth units. i've enabled bluetooth on blackberry. i've set discoverable to yes, and the led connection indicator to on. it...
you also have to have the headset on pairing mode also during the time of the attempted sync, see your documentation on your headsets on how to set it for pairing mode.
Dec 10, 2008 | RIM BlackBerry ® 8830 Cellular Phone
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
RIM BlackBerry ® 8830 Cellular Phone Logo
873 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
