Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Loud cooling fan
My fan is so loud that I need to turn up the volume to enjoy the TV. Is that norrmal for a Panasonic pt 50lc13?
    Sergeant:
  • 300 Answers
No its not normal my fried .do not use the tv.if its under warranty get it replaced or repaired at least.as if not under warranty its the problem of either anything blocking the fan to spin properly or the fan motor is turned weak and needs replaced.if used the tv like this without reparing it will damage the other costly parts of the tv later on.
Posted on Mar 06, 2009
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the lamp on a panasonic tv pt=50lc13 ?
I think you hold down the volume - button on the TV and the SPLIT or PIP button on the TV remote at the same time for 5+ seconds. Becareful that your arm does not block the remote from getting to the TV. A message will appear when you are successful. Best wishes.
Jul 13, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PanasonicPT-50LC13 blink codes
pretty sure this is a problem with one of the cooling fans.
Jul 12, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
NEW BULB INSTALLED FOR PANASONIC PT-50LC13 TV STILL NO LIGHT
close lamp door set will not work with door open. if not that listen for arcing sound in back if  don't hear that bad ballest
Jun 09, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic LCD PT 50LC13. Nothing happens when I push PIP/SPLIT
Make sure you put the lamp DOOR back IN PLACE before turning your TV back on. Then it should all be just ducky.
Mar 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Internal cooling fan
Not aware of any cooling fan in a TV system
Nov 04, 2017 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13
The ballast probably needs to be repaired. A repair kit #LSUC0022 is available from Panasonic.
Jul 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
135 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
