Question about Whirlpool GHW9100L Front Load Washer
Incomplete cycle...Codes H and F...
I just moved and now my Whirlpool FrontLoad Washer (Model # GHW9100L) won't go through the complete wash cycle....It stops and starts flashing code "H", and then code "F". Please help!!!
  • loribranning Mar 06, 2009
    Thank you soooooooooooooo much!!!!
    This was very helpful, and the very first item solved the problem!
    It was actually as simple as making sure the water valves (at the source) were fully opened. I appreciate this help so much!!!
  • Anonymous Apr 02, 2009
    The washer LED reads F11 or dL
  • 300 Answers
Failure code  :---F/H means :----No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
 to resolve this problem this instructions should be tried
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Posted on Mar 06, 2009
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer fills after the cycle is over.
If water is leaking back into the washer after the wash cycle is completed, then the problem is with the water inlet valve. It relatively easy and inexpensive repair. It the part that connects to the hot and cold water lines.
Aug 31, 2010 | Whirlpool GHW9100L Front Load Washer
Whirlpool ghw9100lw frontload washer
Did you firgure out what to do? i have the same problem but have no idea what to do
Jul 10, 2010 | Whirlpool GHW9100L Front Load Washer
My front load duet will complete a full spin cycle but still soaking wet
Are there any error codes on the display like SUDS or E02?
If so this means that it is still taking too long to drain.
When you are running it on the drain cycle listen or look and see if water is coming out of the drain hose.
I would remove the front lower cover put a pan under the white filter assembly. Remove the filter and clean the debris screen. And reassemble also inspect for kink hoses either outside or inside the washer assembly.
Nov 11, 2009 | Whirlpool GHW9100L Front Load Washer
Water refills after a complete cyle. GHw9100L
Had similar problem and ended up being the valve. Try shutting the water off to the wahser during the spin cycle. If the water doesn't refill, that is the issue.
Mar 28, 2009 | Whirlpool GHW9100L Front Load Washer
I have a whirlpool duet washer with a code H problem what is that
Lean the machine back and remove the screws to open the lower panel (kickplate). You should find a tech manual inside which will explain all the error codes.
Jan 03, 2009 | Whirlpool GHW9100L Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
125 people viewed this question
Dan Webster
Dan Webster
Sal De
