Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
HOW TO CLEAN THE FILTER - Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
  • 139 Answers
You can vacuum the filter off. If you do that and still cannot see light thru it then it needs to be replaced. Keeping a DLP engine cool and dust free is the most important.
Posted on Mar 06, 2009
What does it mean when it tell you to clean filter and the filter is already clean
That clean filter symbol is just a reminder to clean the filter after every dryer load--I'm assuming this unit is a dryer, however it's listed under washing machines.
Aug 19, 2015 | Washing Machines
I have the KAWS700GQ washer with a self cleaning filter. My dark clothes are now covered in lint. How can I clean the filter?
go to to clean the self cleaning filter
/how to clean a self cleaning filter for a KAWS700GQ
go to to clean the self cleaning filter.
Apr 13, 2015 | KitchenAid Washing Machines
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
How to clean the filter
Good Afternoon Tad, thank you for allowing me to assist you!
First remove the bucket to reach the filter of your Frigidaire dehumidifier, FAD504DUD. When you locate the filter, pull it downwards. The filter can be clean by either washing it with clean water or using a vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once the filter is reinstalled then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier will resume normal operations.
Hope this helps!
Jan 31, 2014 | Frigidaire Dehumidifier Fad504dud
The filter and compartment are only a portion of the exhaust system. Make sure you clean the pipe from the dryer to the out doors and clean the exhaust fan below the filter.
Good luck.
Jan 24, 2011 | LG DLE5977 Electric Dryer
Changed filter and it still says "clean filter" on the gauge-?reset button
not sure if there is a reset button if not
I would say if the filter was bad enough some of the foreign materials (particles the filter should capture) may have went on down the line.
the "clean filter" indicator is most likely activated by the volume of flow. So when the filter is full the flow is reduced in turn the "clean filter" comes on.
so if filter has been replaced and there is no reset button try backflushing the lines. If the lines have built up blockage your flow will stay low and the "clean filter" will stay on.
on these lines there may be bends and turns most likely to have build up in these areas restricting your flow
clean lines (low air pressure may work easiest)
Mar 03, 2010 | Sunbeam 1117 Humidifier
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
Cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
