Question about Campbell Hausfeld RBWG202000 NA 70 Amp. Wire feed Welder
Looking to put my gun back together on a mig welder model #wf2000 took it apart and forgot how to hook up the wires. please help
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 24 Answers
SOURCE: The wire at the tip of the mig gun strikes an arc
Sounds like the trigger is getting worn out.
Posted on Apr 24, 2009
  • 8 Answers
SOURCE: convert flux to mig
need to buy a gauge set up , these usually come with the hose and gauge,just attach in the back and hook up your bottle..
Posted on Aug 12, 2009
luxur4
  • 92 Answers
SOURCE: campbell hausfeld pro wirefeed welder model wf2000
Check inside the WFU, a switch with CC or CV will be seen, alternate between these two setting, CC=Constant current and CA=Constant Voltage.
On the back of the WFU you will see a plate which indicates the maximum amprage (input) that the WFU can accept and set the main power source to that amprage,
Posted on Oct 09, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Phase three on cv or cc have current going to mig wire, wire is live without hitten gun trigger. mega arc is hooked up to a Hobart suitcase
May need to take gun apart and see if trigger is sticking or replace lead.
we use Miller at work. The feeder has a switch that makes the trigger turn off and on with quick pull of trigger so you don't have to hold it entire time.
check wiring to make sure it's wired right so your not bypassing the trigger switch.
hope it helps.
Nov 02, 2015 | Hobart Welding Tools
I have a lincoln 175+. when i got it i plugged it in an all seemed to work fine. looked like it had been dropped from quite a ways up. the biggest problem was the whole wire feed gear box all of it was...
check the return wire from the hand trigger has been connected to the speed motor wire. Check for a fuse in the system. I have just wrecked a 190 amp welder and I noticed the feed motor assy. was fully insulated from the welder body. Check that out as well as it may be shorting out and not driving the motor.
Sep 22, 2013 | Hobart Handler 140 Mig Welder
How do i get the wire out of te welding line if it is broke off inside
Remove the gun assembly off of the unit and carefully remove the liner from the feed tube, at this point you can usually take a spare piece of wire and push it thru the liner and push out the broken wire, if not then pickup a replacement liner from your dealer and install it reverse of the way you took it apart, and you should be back in bussiness. Hope This Helps Don
Dec 06, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
105 Turbo Model 90778 welder. Took apart the gun/handle because it was not feeding the wire corretly. Put back together and it shorted out. Don't have an exploded view of the handle, to see if anything...
most wire feed problems stem from WF rollers, liners, clutch mechanism on the reel, or contact tip, very rearly on the torch, Torch units are cheap enough and come in a wide range and lenghs, avoid long length cables unless nessasary. you can obtain a drawing of torches from the torch manufacturers
Jun 30, 2009 | Welding Tools
Feed switch came apart, seems to have lost spring out of wirewhip
sounds like you lost a spring i would just get a new gun
Jun 26, 2009 | Welding Tools
Wireing diagram needed for turbo 100 en someone took the gun off and forgot where the wires go HELP needed
Should be matching connectors for the wires inside the welder. If not one is power should be a large wire that powers the gun and the 2 smaller wires should be for trigger swich for wire feed/gas on/off..
Jun 08, 2009 | Welding Tools
Wire does not feed on MIG welder
my lincoln mig welder did the same exact thing!! I thought what you did, drive motor bad. But it wasn't, on mine there is a reset/breaker button, it's like a 25 amp fuse that can be reset, it was bad! so I took the 2 wires that went in and out of it and jumped them together (not advised) to see if it would work then. BINGO!! now I have to find replacement. Look inside for a fuse or some thing like that.
hope this helps, oh yeah, when I ask the mechanic at the welding store he said that drive motors rarely go bad!!
Hawk
Apr 10, 2009 | Welding Tools
Need wiring schematic for miller 140 wire feed welder
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Campbell Hausfeld RBWG202000 NA 70 Amp. Wire feed Welder  Logo
122 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
