Question about GE Spectra JBP78 Electric Kitchen Range
Help. I have a Truetemp GE Range. The oven heating element went out(it uses part no#wb44x10016)sorry, I don't know the model number. Anyway, How do I take it out and/or replace it?
  • GE Master
  • 3,361 Answers
Unplug the range.
Remove the oven racks.
Remove 2 screws holding the element to the back wall.
Slide the element towards you carefully. Remove the wires and install them on the new element.
Reattach the element to the back wall.
Posted on Mar 10, 2009
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
GE electric range Model: JBP24W084WW
You can order one from Repair Clinic Here is a link to the part and a video on how to change it
http://www.repairclinic.com/PartDetail/Bake-Element/WB44X10016/260870
Oct 08, 2012 | General Electric Stove, Range, Oven GE...
Frigidaire ES200 Electric range - last night while making dinner, I noticed a strange light coming from in the oven. I looked inside & one side of the lower/bake element was literally in flames. I...
Hello Damaya,
I am sorry to inform you that this is not the proper model number of your unit. The model number you give is for a Frigidaire electronic air cleaner. Your model number should be located in side or around the facing of the oven or compartment below the oven. If you can post back to this thread I will be more than happy to locate the cow-rod you need for you oven and explain how to change out the part.
Thank you for using FIxya and please do not hesitate to ask questions.
Mar 09, 2011 | Frigidaire Kitchen Ranges
I have a GE TrueTemp oven/range - oven is not working
I had a similar problem.The power failure might just have been a coincidence.Sounds to me like your lower oven igniter may have gone bad such as mine did.
Jul 14, 2010 | GE JGBP33 Gas Kitchen Range
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing baking element for GE Truetemp
I just had the same problem. Just remove the rear panel of the range and unplug the two leads. Now go to the two screws inside the oven and remove them. The heating element will now come out and you can insert the new element the same way. Replace the two screws inside the oven and then attatch the two leads in the rear. Replace the rear panel and you are set to go.
Jan 25, 2009 | GE Spectra JBP78 Electric Kitchen Range
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Aid Superba Range
We got one used too. It would kinda heat up on broil and would not heat up for Bake. There is two heating elements the one on the top is only for broil or convection (partially). The other is under the cover on the bottom near the back of the oven it is primarily for Baking. We have a repair plan through our utility company and they replaced that heating element which is why I cannot give you too much specifics on how to get to it, but it is there and it fixed our problem. Hope this helps we absolutely love this oven now that it works so keep trying!!
Nov 19, 2007 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
318 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
