Kyocera 3530: Close front cover
I have a Kyocera 3530, the copier says to close the front cover, but the cover is closed. I manually push on the sensor, but it still says it is open. Is there any way to tell what the problem is?
    Scholar:
  • 136 Answers
OK here is what I like u 2 do
First do u have a meter that Can measure conentuety ? or shorts, well what I like u 2 do is remove the sensor from the copier or remove the connectors from the rear of it, then I like u 2 take a meter and measure the resistances of it, if u get a beep then you know it is closing if not you may have a bad sensor, so do this first then tell me what r your results
Posted on Mar 08, 2009
Kyocera FS-C5100DN shows Error message "close front cover" what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
Mar 29, 2017 | Kyocera FS-C5100DN Color Laser Printer 23...
Wont operate because display says 'close top cover' even though it is closed.
If you remove the toners you'll see a little lever usuall has a yellow sticker attached that can be pushed forward or back make sure it's pushed towards the back of the machine then reload the toners and close
if it still won't close you may have broken the actuator off the lid that pushes the switch when the closes
Mar 15, 2015 | Kyocera FS-C5100DN Color Laser Printer 23...
If you remove the toners you'll see a little lever usually has a yellow sticker attached that can be pushed forward or back make sure it's pushed towards the front of the machine then reload the toners and close
How to reset a process unit
Make sure that the front and top covers close smoothly and fully. If the blue toner release arm is not fully to the rear the top cover will barely close. To reset the process unit you should remove it and then re-install it making sure it makes a good 'click' when you insert it.
Apr 15, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
Kyocera Mita KM-2530 error close front coveR
The front door switch or actuator is broken or the door may be warped .Have you tried putting pressure on the front cover? as this may help to indicate if the switch is faulty.
Sep 10, 2012 | Kyocera Mita KM-2530 Laser Printer
I keep getting a close feeder error on my Km Kyocera 1530,how do i go round it
Assuming the feeder is closed and you are still getting the message to close feeder the one of your interlock switches are bad or not making contact.
Each cover that open and closes has a switch to indicate it is closed. Make sure when you close the cover the switch is being actuated.
To find the switch open a cover then start to close it and look for a piece of the cover that is going to line up with a hole in the feeder when it closes, this is normally where the switch is.
If you have a multimeter and know how to use it you can ohm out the switch to make sure the switch is working.
Sorry I can't be more helpful but this machine was not manufactured by Kyocera (it was just sold with their name on it) and I am not overly familiar with it and the documentation is not very good on the machine.
Mar 04, 2011 | Kyocera Mita RADF-11 REVERSING...
I am getting Call Service 7410:00 32266 on FS-3900DN Kyocera Laser Printer.
You have pulled the drum unit out of position possably after changing the waist toner ? Open the back cover, open the frunt cover and remove the developer unit, the full unit not just the toner, open the side cover where the waist toner bottle is and push the drum unit back into place until it clicks, put the dev unit back in place and close everything reboot the machine
Apr 18, 2009 | Kyocera FS-3900DN Laser Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
194 people viewed this question
k24674
jasbo
jasbo
