Do you access under the dash and if so, what is the procedure
You can do it one of 3 ways...
a. Remove the Instrument Cluster from in front of the wheel, Lubricate
b. Remove the Cable from Under the dash and Lubricate
c. Remove the Cable from the Transmission and Lubricate.
Removing BOTH ends and cleaning first from Pressure TOP to Transmission is highly recommended and injecting a Light Lithium Grease I have found to give the best results but if you are having a problem with the Speedometer Cable itself... They are inexpensive and easy to replace. That is what I would do if it was making noise.. Less than $30 for a new cable
SOURCE: How do you replace the dashboard light bulbs in a
it sucks but there is a plastic clip on the cable were it goes in the cluster . and yes you need to pull the cluster to chang the bulbs
SOURCE: Clutch/starter interlock switch no longer engages.
the solenoid that pulls the interlock pin back is located on the top of the sterering column, drop the column down to access it, are u sure the brake lights work? that is what energizes the solenoid.
SOURCE: Does the dash have to come off to access the air
Hello. Thanks for choosing Fixya! In order to access the air bag module on the 1996 Taurus the entire dash must be removed and the air conditioner refrigerant must be pumped out. I hope this answers your question. Regards, Joe
Fig. 1: On this truck, the equalizer is just behind and to the side of the transfer case
Fig. 2: Common front brake cable mounting (click image for zoom)
Fig. 3: To loosen, hold the adjuster rod from turning while you turn the nut using a box wrench
Fig. 4: The cable is usually attached to the lever using a button retainer
Fig. . . . then extract the assembly
Fig. Detach the cluster wiring, you may want to label them prior
Fig. Remove each bulb individually and inspect for replacement
