Question about NetGear WGR614 Wireless Router
To un-bridge my modem
What I want to know is how to unbridge my modem and by-pass my router? I know I have to go to 192.1.1 address or something like that to start.
  • 28 Answers
You're talking about just hooking your PC directly into the cable/dsl modem?
If so, you should be able to just unplug the LAN cable from the router and hook it into your modem.
(Most XP/Vista installs are set to seek out a DHCP server to get an IP. Your home router was your DHCP server before, hence the 192.168.x.x addresses.)
Posted on Mar 06, 2009
How do i acces my modem to get it out of bridge mode to use it without a router
Hi paintballa12!
Here's the link for yor modem's userguide..
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
Normally, all dsl modems can be "unbridged" byr resetting it to factory state.. But that would mean you have to save you DSL username & password again..
Check page 38 for setting modem to non-bridge mode..
Hope this helps..
Mar 10, 2011 | Efficient Networks SpeedStream 5200 Modem
My WRT54GC router suddenly stop passing internet through it after 4 years of uninteruped service. But all the LED s are on as they should be. I can not get either wired (my desk top) or wireless (lap top)...
Has your modem been hard reset recently? if so, it may require that you bridge the modem out to work with the router- ESP. if you use Verizon DSL. If so, contact your ISP, and ask for assistance in bridging out the modem.
Oct 03, 2010 | Linksys WRT54GC Compact Wireless-G...
Cannot connect to att DSL through Linksys router.
hi
I've tried:
Having the router get an IP automatically from the modem.
Changing the router's IP address.
Having the modem pass PPPoE authentication to the router.
Bridging the modem.
Power cycling the guts out of everything.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
I need to get my 1000hw out of bridge mode. My dad gave me an old 2wire moddem thing and I cant get it out of bridge mode because I am not comuter literate. Can someone please tell me simply what to do so...
you need to reset the modem, look for the reset button of your modem, it just beside the port for your power cord.if you dont see anything like it. call 2wire for them to assist you for unbridging the modem
Jun 26, 2010 | 2wire HomePortal 1000HW DSL Modem and...
2-Wire 3800HGV-B bridge mode
Hello my friend,
You can disable all routing functions for your Home Portal. I never advise this as a course of action as it typically causes more issues than it resolves - so procede at your own risk.
- use the button on the back to reset to factory state (hold for 30 seconds)
- browse to gateway.2wire.net/mdc
- click on configure under broadband link
- set ATM PVC search to disabled
- set connection type to direct IP
- click on configure services under the advanced heading
- take note of the text under "If you want to connect to the gateway when it is in bridged mode"
- un-check the enable routing box
- submit your settings
Good Luck!
Oct 30, 2009 | 2wire HomePortal® 1800HW Router...
Distributing the internet either by wireless or by Ethernet cable
Sounds to me that the router is not recieving the signal from the Modem. Some Modems require you use a 'cross-over cable' to plug in a router like that (from modem to WAN on D-link). Make sure the IP address of the D-Link is on the same subnet as the Modem, i.e. the cable modem is preset with an ip address scheme (proabably 192.168.0.1 or something) and your router should have the same 192.168.0.x address depending on what the modem is).
Another thing you can try would be to "bridge" the modem to the router.
Look here, http://www.computing.net/answers/networking/dsl-modemrouter-in-bridge-mode/28151.html
Also if you need troubleshooting walkthrough Im available http://www.hoosierpcrepair.com
Jun 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Hello, I currently use a Belkin F5D8631 as my Modem Router. I have a spare Belkin F5D7633. Can I use the 7633 as a repeater/bridge to extend my wireless range? If so, how?! Thank you
It will not extend your wireless range. If you connect your spare Belkin F5D7633 to your Belkin F5D8631, one of them would have to be set to "bridge mode" or a pass through modem so that there will be no conflicts as to which modem will receive the ip address from the network. If you set your modem/router to bridge mode, it would disable its wireless function because it will only be a pass-through device.
If you want some tips on how to improve your wireless range, check out this site http://www.microsoft.com/athome/moredone/wirelesstips.mspx. Hope this helps.
Apr 22, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
RE: HP Pavilion dv6300 series laptop I have no wireless capability---suggestions???
If it had wireless before, go into the control panel click on network connections and you sould see all you internet connections. Usually one wired and one wireless. Sometimes a third one depending on your computer. Right click on the wireless one and check you "bridge connection" and if unbridged bridge it, If bridge un bridge it. Then try you wireless, make sure you are near a router for a strong signal. If it does not change go back into the control panel and set your bridge connection where it was. This would tell you it is something else.
Aug 28, 2008 | HP Computers & Internet
D-Link Router & Actiontec Modem
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping yahoo.com and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
Oct 24, 2007 | Computers & Internet
NetGear WGR614 Wireless Router Logo
438 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
